Old 02-26-2015, 02:19 PM   #1
M23
Drives: 86
Cusco Touring-A Shocks/Struts - OEM Replacements
Just starting a new thread for the new Cusco replacement shocks/struts - Touring-A model.
I've read CSG is testing them currently. Though, if anyone else gets them in the future, or if any shop gets the chance to test them, please share your impressions/reviews about them.
Comparisons against similar products are more than welcome as well (eg: Koni, Bilstein, etc.)
http://www.cuscousainc.com/products/...touring-a.html
http://blog.cuscousainc.com/?p=642
M23 is offline   Reply With Quote
The Following 2 Users Say Thank You to M23 For This Useful Post:
Black Tire (02-26-2015), Hyper4mance2k (02-26-2015)
Old 02-26-2015, 03:33 PM   #2
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I would love to find out if these adjust compression & rebound together, or just rebound like the Koni's.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 02-26-2015, 03:35 PM   #3
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Same here. I'm also very curious how these compare to Konis.
G_Ride is offline   Reply With Quote
Old 02-27-2015, 12:52 PM   #4
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Here's Cusco's reply.
Hello Adrian :
Thanks for inquiry.
Touring - A is upgrade kit for stock suspension.
Which is stroke is about same as stock shock.
It is 40 steps adjustment for rebound only.
20th step is about same as stock shock.
and the hardest set is 140 % stiffer than stock.
Please check our link here :
http://www.cuscousainc.com/downloads/dl/file/id/230/cusco_touring_a_suspension_kit_new_in_2014_for_sub aru_applications.pdf
and for Electric control unit :
http://www.cuscousainc.com/products/...ontroller.html
Old 02-27-2015, 02:06 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
While these should work well with the stock springs, I am very interested how they will work with springs like the Swift Sport, or Swift Spec R. Cusco states on their website that these shocks will work with aftermarket lowering springs that are designed to work with the stock suspension. Also, I would like to see how this setup would compare to the new Tein Flex Z or Tein Flex A.
Old 02-27-2015, 02:15 PM   #6
simpleisbest
Senior Citizen
Drives: Scion FR-S
I would bet they are just rebranded Koni's with a clicker added....LETS SEE SOME DYNOS!
simpleisbest is offline   Reply With Quote
Old 02-27-2015, 03:02 PM   #7
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
I highly doubt they're rebranded Koni's. I have recently contected both Koni and Cusco and the are drastically different. The Cusco's are the same as stock on click 20 (as posted above) and will go as firm as 140% above stock, where as the Koni's are as as firm as stock on 0 setting and at full 2 turns are 100% stiffer than stock. Both are only rebound adjustment.
Koni stated most customers with aftermarket springs run their shocks 1/2 to 1 turn.
Old 02-27-2015, 04:16 PM   #8
simpleisbest
Senior Citizen
Drives: Scion FR-S
Valving changes. You know you can have koni yellow's revalved, right? I ran OTS koni's for almost 2 years on stock springs. From day 1 they were way softer than stock on full soft...
Old 03-01-2015, 08:57 PM   #9
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
So with the Econ2 its around $1600? Yikes. Wish the Econ2 was cheaper...
But for $1000 its around $100 more than the Bilsteins and you get adjustability.
Kostamojen is offline   Reply With Quote
Old 03-02-2015, 07:05 PM   #10
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
But no warranty... Our 3 shock options sure are give & take... There's no clear winner in all categories.
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
bass_114 (03-02-2015)
Old 03-04-2015, 08:11 PM   #11
CSG David
CSG David's Avatar
The upper limits of the shock are pretty good. It makes the car very predictable and easier to drive...as if this car isn't easy enough to drive already...
The Following User Says Thank You to CSG David For This Useful Post:
Hyper4mance2k (03-04-2015)
Old 03-04-2015, 11:45 PM   #12
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
But are they $150 better than the Bilsteins. I'm pretty sure I might go with the Bilsteins, unless someone out there can convince me otherwise.
Old 03-05-2015, 01:56 AM   #13
CSG David
CSG David's Avatar
That is unconfirmed. There has not been a back to back to back comparison of these setups. Bilstein is a fixed spec. Koni has some adjustment. Cusco has a ton of adjustments. If you understand the suspension market well, Cusco works closely with a very well known suspension company (deals mainly with OEM markets) to co-develop their kit. I can't tell you if it is better than one another or not, but I can tell you they do pretty well especially as a replacement shock.
Hyper4mance2k (03-05-2015)
Old 03-05-2015, 02:23 AM   #14
Kostamojen
Just to clarify, are they or are they not designed to work with lowering springs?
Stock rear shocks / struts gone at only 40,000 miles? Black Tire Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-21-2019 11:52 AM
**NEW**Bilstein B8 HD Struts and Shocks Released FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 09-12-2016 01:54 PM
Koni Yellow Shocks - Full Front Replacements - Released FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 08-23-2014 09:57 PM
FS: BRZ/FRS shocks, struts & sway bar end links BRZ'13 Canada Classifieds 0 07-02-2014 02:23 PM
Bilstein shocks & struts Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-31-2013 02:56 AM
