Old 02-22-2015, 11:20 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Which Meguiar Product Removes dirt and grime?
Looking for a product which safely lubricate the dirt and grime, allowing it to glide from the vehicles paint without affecting the clear coat. Without touching the car just yet, I will hand wash it afterwards.
However, I am only looking for the product that will allow most the dirt and grime to be removed with a rinse.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 02-22-2015, 11:29 PM   #2
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Might have to resort to mechanical methods, like a pressure washer. Or a foam cannon to help the soap stick to the surface longer to do it's dirt lifting magic?
aegisdrgn is offline   Reply With Quote
Old 02-23-2015, 11:05 AM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
those are just car soap,
you want pre-wash that will loosen the dirt/grime before giving it a good rinse/hand wash
your not gonna find the best products to do this job at your local Auto Zone IMO
Old 02-23-2015, 12:23 PM   #4
Mikeez
Engineering Student
Indeed, to wash the car I will have to go mechanical method. Before I do, I want to find a chemical-aid that will help lift off most of the dirt and grimes. I just need a spray, I found few online.. but expensive to export to Canada.
I've been suggested a powerful pre-wash chemicals.. but they are expensive to export.
I will give it a hand wash once I pre-wash it touchless. The reason why, is to clean the car at least 50% before actually hand washing....
Old 02-23-2015, 01:11 PM   #5
WhiteFRS69
WhiteFRS69's Avatar
if your going to hand wash, use the two bucket method and invest in some grit guards for your buckets
wash one panel at a time
also look into the Garry Deen wash method, popular way of washing a car
Old 02-23-2015, 01:19 PM   #6
Mikeez
Engineering Student
I know the double bucket method and the way I wash the car is the following:
- 2 buckets
- Panel / Panel ONLY top part
- Panel / Panel ONLY Med part
- Panel / Panel ONLY last part
Anyways, I don't want to know how to hand washh..
I just want a chemical substance that will help me remove most of the dirt before hand washing...... The soap doesn't do anything touchless. Any touchless method before actually hand waching????
Old 02-23-2015, 01:22 PM   #7
WhiteFRS69
WhiteFRS69's Avatar
- 2 buckets
there are tons of products available, but from my knowledge, meguiars does not have a pre-wash
find a company in Canada that provides products like Sonax, Auto Finesse, etc etc
i personally been using Auto Finesse Citrus Power grime remover like i mentioned before
Old 02-23-2015, 02:11 PM   #8
WhiteFRS69
WhiteFRS69's Avatar
you could always invest in a steam cleaner, that would help break down salt/grime
Old 02-23-2015, 02:27 PM   #9
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Pressure washer and a foam cannon.
Prespray with the pressure washer to remove largest particulates. Foam cannon with some nice foaming soap and let dwell for 5 minutes. Then pressure wash again to remove soap and remaning road grime.
Anything this method leaves behind you'll need to physically touch the paint to clean it further.
Kotu100 is offline   Reply With Quote
Old 02-23-2015, 03:19 PM   #10
WhiteFRS69
WhiteFRS69's Avatar
believe he is looking for something like ONR, where its a waterless wash
but he is looking for something that will cut down the grime/salt without harming the vehicle
Old 02-23-2015, 07:30 PM   #11
Kotu100
Kotu100's Avatar
Personally I'm not a fan of swirl marks in a bottle.
OP if you have access to a self serve car wash it may be worth the couple bucks to just use the pressure washer and soap, if you don't want to or can't hand wash it.
*edit* Just a FYI, I use Gold class in my foam gun and the foam is thick. It definitely grabs hold and loosens up some dirt that the initial rinse didn't. Special foaming soaps don't NEED to be used. The pressure of the pressure washer matching the recommended pressure on the foam cannon is what gives great suds.
Old 02-24-2015, 01:57 AM   #12
Mikeez
Engineering Student
Okay guys, I know what to do...
I will buy a pre-wash and just apply it and wait for summer ;3'
Thanks for the help
Old 02-25-2015, 05:52 AM   #13
SurfAndSand
8SiX
Drives: FRS 10series
Spray it down with good pressure. Wash it using your preferred method. Clay bar it. Then hit it with some polishing cream and a random orbital buffer?
SurfAndSand is offline   Reply With Quote
Old 02-25-2015, 11:43 PM   #14
Mikeez
Engineering Student
Guys I am not asking how to wash the car =p. Is there any chemical that I can spray my car and then when I pressure wash my car... most or little dirt and grimes fall off?
Great finish using Meguiar's and Nanowax together babydriver Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 01-26-2015 08:28 AM
Meguiar's Hot Rims Wheel Cleaner - Safe? billyk Cosmetic Modification (Interior/Exterior/Lighting) 8 12-19-2014 03:26 AM
Dirt Cheap Vinyl ButtonMasher Cosmetic Modification (Interior/Exterior/Lighting) 6 11-17-2014 10:00 PM
Meguiar's Scion FR-S on the cover of DSport! MotivConcepts Scion FR-S / Toyota 86 GT86 General Forum 17 05-01-2013 03:50 PM
Meguiar's microfibre wash mitt Ontariofrs CANADA 8 05-01-2013 12:50 PM
