Old 12-18-2014, 07:25 AM   #1
billyk
billyk's Avatar
Drives: 2014 Argento FR-S
Meguiar's Hot Rims Wheel Cleaner - Safe?
I know that Meguiar's makes a few levels of cleaners and that this is the middle level. I've read negative reviews about using this on some wheels. Is it safe for the OEM FR-S wheels?
billyk is offline   Reply With Quote
Old 12-18-2014, 07:35 AM   #2
MadeInSweden
Drives: Nissan GT-R
Used it on my GT-R before and I cannot believe that OEM FR-S wheels could be damaged. Meguiars usually knows their stuff.
Nurburgring 07:42 BTG
MadeInSweden is offline   Reply With Quote
Old 12-18-2014, 08:52 AM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
... would they sell you acid as a wheel cleaner?
Old 12-18-2014, 09:07 AM   #4
adamg
Drives: brz
Never heard of Meguiar's, sounds really sketchy
adamg is offline   Reply With Quote
Old 12-18-2014, 10:25 AM   #5
billyk
billyk's Avatar
"Used it on my GT-R before and I cannot believe that OEM FR-S wheels could be damaged. Meguiars usually knows their stuff."
Yep, thought so. Just checking.
Thanks!
Old 12-18-2014, 07:59 PM   #6
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
http://www.meguiars.com/en/automotiv...-tire-cleaner/
Safe for all wheels. If you like it save the spray bottle and get this stuff....
http://www.meguiars.com/en/professio...ner,-1-gallon/
Even diluted to 35-40% strength it works just as good or better than the all wheel cleaner.
Kotu100 is offline   Reply With Quote
Old 12-18-2014, 09:00 PM   #7
White64Goat
I use the purple 'Super Clean' and that stuff will literally make your hands have dryness +10 and you can feel it peel the skin when dry and I use it on the wheels with no problem, (along with rubber gloves) so I doubt a wheel cleaner made to clean wheels will hurt them. Always read the label though, just to be sure.
Old 12-18-2014, 09:06 PM   #8
billyk
billyk's Avatar
Thanks guys!
Old 12-19-2014, 03:26 AM   #9
Poodles
Drives: 2015 Series.Blue
Yep, I remember some wheel cleaners being highly acidic and damaging if left on for more than 15 seconds. Thankfully I haven't seen them on the market in years.
Super Clean eats paint and aluminum, it's definitely not what you want to use on your wheels. It also dries out rubber, so another strike against it.
General purpose degreasers all have issues like this (Super Clean, Simple Green, etc). They're really not designed for automotive use like a true engine degreaser is. True engine degreasers won't damage any base materials like paint, aluminum, rubber, plastic, etc
FYI: Super Clean is so good at removing paint, it's often used by model builders to safely remove paint from clear plastics. Like for instance you screwed up painting the frame of an aircraft canopy.
Wheel Cleaner! Stay Fresh Car Care Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 09-23-2014 07:06 PM
For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95! DetailersDomain Cleaning and Detailing 0 03-25-2014 01:25 PM
Recommendations for Wheel Cleaner? FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 03-16-2014 03:51 PM
Great deal on wheel cleaner! rokius Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 02-22-2014 07:00 PM
Here's your shot to WIN A LOT of Sonax Full Effect Wheel Cleaner DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 01-18-2013 07:15 PM
