Old 02-21-2015, 12:54 PM   #1
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
TEIN SUPER RACING (SRC) - CSG Spec
CounterSpace Garage is proud to announce the release of the CSG Spec TEIN SRCs!!
97 test days at the track
3742 laps
61968 miles
872 million data points
2682 gigabytes of video footage
3742 gallons of gas
60 tires
9 sets of brake pads
24 citations
2 BRZs
5 engines
29 months
These are the numbers that culminate in today's announcement.
CounterSpace Garage is proud to present the CSG Spec Tein SRC for performance enthusiasts. Originating from years of testing by CounterSpace Garage at the race track, Tein has customized the SRC with specifications developed by CounterSpace Garage. Optimized for high performance driving, these coilovers are designed to maximize grip both on the street and at the track.
www.tein.com Description:
Developed from actual competition, TEIN was able to create a fully adjustable damper that can be easily tuned for any track and weather conditions. Super Racing Dampers utilize a full-length adjustment system to allow shock length and spring pre-load to be adjusted independently. Separate 16 - way adjustments for compression and rebound damping enable the user to fine tune for any situation. TEIN has incorporated both camber and caster adjustment into the front pillow ball upper mounts for strut type vehicles. External reservoirs on SA type dampers allow for added oil capacity. Spring rates and shock valving were derived from many years of motorsports support, to provide the ultimate damper. Designed and tested for by advanced and professional drivers who are seeking complete damper tuning capability. [/quote]
Photo Courtesy of Super Street
To accurately represent the performance enthusiast, CounterSpace Garage utilized a lightly tuned BRZ to develop this damper kit. The concept behind the damper is to produce a performance coilver that could be used to drive to the track, compete and drive home. the primary focus of these dampers is track performance, While retaining street manners and comfort.
Specifications:
• 7kg/mm - 13kg/mm front spring rate, 10kg/mm springs included
• 9kg/mm - 15kg/mm rear spring rate, 12kg/mm springs included
• Steel Construction
• Mono Tube internal construction
• Inverted design for strut type front and rear
• Ride Height adjustable via threaded body and spring seats
• 16 × 16 way adjustable dampers, compression and rebound separately adjustable
• Pillow ball upper mounts for increased steering feel, front and rear
• Upper and lower camber adjustment on front
• Caster adjustment on front
• Dual EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
Contents of Damper Kit:
Adjustable Shock Absorber × 4
Main Spring × 4
Helper Springs × 2
Pillow ball Upper Mount × 4
Lower Spring Seat × 4
Seat Lock × 12
Bump Rubber × 4
Hook Spanner × 2
Dust Cover × 4
Instruction Manual × 1
Sticker Sheet × 1
Optional Spring Rates:
• We recommend an additional set of 9kg/mm front 10kg/mm rear springs for those that prefer a more compliant ride.
• 12kg/mm front 14kg/mm rear spring rates recommended for cars driven exclusively on R-compound or slick tires.
TEIN USA Home - The Official TEIN Site - Coilovers, Lowering Springs, Performance Suspension...
www.tein.com
CounterSpace Garage Blog - TEIN SRC - CSG Spec - Announcement
GROUP BUY THREAD IS UP!!
CounterSpace Garage is offline   Reply With Quote
The Following 22 Users Say Thank You to CounterSpace Garage For This Useful Post:
Andrew360 (02-21-2015), Anthonytpt (02-26-2015), BatStig (02-21-2015), Black Tire (02-21-2015), cjd (02-21-2015), FRSCanuck (02-21-2015), fstlane (02-21-2015), fx35s (02-22-2015), jonbonazza (02-22-2015), Jonsey (02-22-2015), juliog (02-21-2015), liquidsky44 (02-21-2015), M23 (02-21-2015), mkivsoopra (02-21-2015), mokinbird87 (03-03-2015), MyRx (02-21-2015), Racecomp Engineering (02-21-2015), RehabJeff86 (02-22-2015), Scottemad123 (02-22-2015), Superstar (02-25-2015), ultra (03-21-2015)
Old 02-21-2015, 02:04 PM   #2
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I feel like Wayne Campbell drooling over Excalibur. These will be mine. Oh yes, these will be mine!
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
fatoni (02-22-2015)
Old 02-21-2015, 02:13 PM   #3
juliog
juliog's Avatar
Drives: 86
I shall have mine re-valved to CSG spec at some point . Amazing on track and very comfortable on the street on softer settings.
Sent from my iPotato
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
Old 02-21-2015, 02:44 PM   #4
Ro_Ja
Drives: TOYOTA
3742 laps
61968 miles
3742 gallons of gas
60 tires
24 citations
2 BRZs
5 engines
29 months
Outstanding. I wish my employer applied this level of R&D to our suspension products.
Ro_Ja is offline   Reply With Quote
The Following 3 Users Say Thank You to Ro_Ja For This Useful Post:
CSG Mike (02-21-2015), jonbonazza (02-22-2015), wparsons (02-21-2015)
Old 02-21-2015, 03:14 PM   #5
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
3742 laps
61968 miles
3742 gallons of gas
60 tires
24 citations
2 BRZs
5 engines
29 months
Cheeseballs is offline   Reply With Quote
The Following 5 Users Say Thank You to Cheeseballs For This Useful Post:
Black Tire (02-21-2015), CSG Mike (02-21-2015), Hyper4mance2k (02-21-2015), M23 (02-21-2015), wparsons (02-21-2015)
Old 02-21-2015, 07:57 PM   #6
FoolsGold
Any new threads started about "which coilovers should I buy?" should just be pointed here and then locked.
FoolsGold is offline   Reply With Quote
The Following 3 Users Say Thank You to FoolsGold For This Useful Post:
Anthonytpt (02-26-2015), Captain Snooze (02-21-2015), juliog (02-21-2015)
Old 02-21-2015, 08:41 PM   #7
wparsons
wparsons's Avatar
About freaking time
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 02-21-2015, 09:26 PM   #8
Scottemad123
Drives: 2014 SWP BRZ Limited
Want, much want.
Scottemad123 is offline   Reply With Quote
Old 02-21-2015, 11:03 PM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
Just in time (I hope!) to add these (if I can figure out HOW... I assume I actually have to deal with a person!) to the growing pile of parts, get them installed and the car set up for AutoX season. Have just about everything but a garage warm enough to work in (it warmed up to 28 today, and we had plans...) Haven't driven the car in over a month (nor any car, for that matter...)
Soon.
C
Old 02-21-2015, 11:56 PM   #10
Andrew360
Andrew360's Avatar
Drives: Whiteout FRS, 07 Stg 2 Vw GTI
My God... This is beautiful.
Andrew360 is offline   Reply With Quote
Old 02-22-2015, 12:36 AM   #11
dabocx
dabocx's Avatar
Drives: Scion FRS
Would love these but I think ill have to settle for some lower end coils in the 1.5-2.5k range. I can dream though
dabocx is offline   Reply With Quote
Old 02-22-2015, 04:13 AM   #12
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Yes! Yes!! Yes!!!! Take my money pls!!!!!!
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 02-22-2015, 03:40 PM   #13
kster1
kster1's Avatar
What's the difference between these CSG TEIN SRC's and the standard TEIN SRC's which sell on your site for about $3700? Is it just the shock valving? Any difference in parts? Sorry if I missed this in the product description. Can you elaborate more on these differences please?
I am debating between getting my Ohlins R&T revalved/rebuilt or purchasing one of the TEIN SRC models instead.
kster1 is offline   Reply With Quote
Old 02-24-2015, 12:22 AM   #14
They are custom valved to emphasize high performance driving. The car will better absorb surface imperfections under a cornering state, and respond with more immediacy to driver input.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
Anthonytpt (02-26-2015), BatStig (02-26-2015), kster1 (02-24-2015), RehabJeff86 (02-24-2015), wparsons (02-24-2015)
Tein SRC (Super Racing Circuit) Coilover Review CounterSpace Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 83 03-26-2019 08:19 PM
FS: Tein SRC (Super Racing) in Socal mtsui Brakes, Suspension, Chassis 3 01-27-2015 10:25 PM
CSG, Tein, Rays, AP Racing, Cusco, Berk, APR CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 7 07-03-2013 06:32 PM
BRZ - Super GT Racing Sounds TRD_86 BRZ Photos, Videos, Wallpapers, Gallery Forum 7 03-18-2013 07:16 PM
Enjuku Racing - Tein S-Tech Springs - ** ON THE SHELF ** Enjuku Racing Brakes, Suspension, Chassis 0 08-14-2012 05:06 PM
