Drives: '23 BRZ Limited
18x9.5 ET38 RPF-1 BBK clearance
Does anyone know if these will clear the Essex spring kit? I was hoping since the 17x9 ET 35 did, these would as well.
Can anyone confirm fitment? |
They do, found this post searching in a different thread. I wish they would list it on their web site!
http://www.ft86club.com/forums/showp...&postcount=102 |
Old thread but anyone know if +45 offset on 18x9.5 rpf1s will work with a wilwood 6 piston set? I saw the AP kit fit with +38 and that AP is a lot bigger than wilwood.
I also know a 17x7+42 set fits on the wilwood set. If anyone has the +38 rpf1s could measure the space with their wilwood set for me that would be cool. Someone wants to trade me and his are +45.
#4 | |
Drives: Scion FR-S, Ultramarine
"Stage II will require a spacer to fit with RPF1's 18x9.5et38. RPF1's are a great wheel, but they have very poor caliper clearance. Enkei PF01's are much better for caliper clearance. Stage I's should fit your RPF1s, but please verify with the template." It just depends on the type of caliper you're buying, because wilwood has the narrow superlites, and suplerlites which are wider and hold thicker pads & heres their wheel template for their kit with the regular superlites: http://www.rr-racing.com/v/vspfiles/...tageII-BBK.pdf |
#5 | |
I guess I could always trade the guy wheels and if when I put the BBK on it doesn't fit I could grab spacers for the front..
#6 | |
#7 | |
How much room do you have? If you could snap a picture that would be awesome too.. I may just trade the guy. Let's see.
#8 | |
But the issue with rpf1's is that their spokes are more recessed, which is why people might have issues fitting some big brakes. My weds sports are super concave so I'm not worried about clearance issues when I upgrade to big brakes. |
Ft86speedfactory actually took the template to the wheels and tested them for me. They didn't have the +45 in stock on that size but said there's a bit of room on the +38s so guessing the 7mm extra should fit.
| 18x9.5 e45 - 255/35/18 Tires - Front Strut Clearance | Kuri | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-12-2014 10:30 PM |
| SOLD - FS: Rays 57DR wheels 18x8.5 ET38 (SoCal) | bino | Wheels and Tires | 5 | 04-03-2014 01:36 PM |
| 17s & BBK clearance | ultra | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-04-2014 04:53 AM |
| Blow out Sale on Enkei RPF1 18x9.5 5x100 et38 Tony Angelo Edition @ Prime Motoring! | PrimeMotoring | Wheels and Tires | 1 | 01-11-2014 09:59 PM |
| SOLD! FS: Tom's TN06 18x7.5 ET38 5x100 (SoCal) | bino | Wheels and Tires | 7 | 06-07-2013 09:19 AM |
