| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Best used track car for about 7500$ and small amounts of dd
I am not sure how feasible this sounds but i am tired of having a 300$ plus car payment. I love the frs but as a daily driver, its wearing thin. I am wondering if having a dedicated track car and some time in the future a comfy car in the future would be a better bet. It would also have to be my dd for a year or 2. Main requirements would be light and rwd. Cheap and solid after market parts. Also around the same power to weight ratio as the frs if possible.
2013 Series 10 FRS #553
Answer is Miata.
2022 BRZ Build 2013 FR-S Build |
miata. 240sx, bmw's like e36 m3 and maybe some american.
JHerbert Racing
Drives: 2013 Scion FRS
I've been looking into a first gen MR2. They have been completely forgotten and people are practically giving them away. I was hell bent on buying an AE86 then ran into these. And oh yah, the 20v 4AGE drops in. (need to modify engine harness)
Site Moderator
Drives: Stuff
I like AW11 MR2s but I wouldn't use one for a track car that sees DD usage as well. IMO a SW20 NA would be a better dual use MR2. Very few high end dampers exist for the MR2 (which doesn't mean you can't go the custom route but that's more costly) and other parts aren't all that plentiful. The AW11 NA cars are fun and very light though.
However, by far the correct answer to this thread is a Miata.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#7 | |
JHerbert Racing
Thinking back, I probably shouldn't have been so succinct in my answer. If you're going to DD it, one major downside to a track-prepped Miata is that you'll be driving on the street with a roll bar and no helmet. It's up to you whether you want to take on that risk. Definitely something to consider since you said you'll need to DD it for 1-2 years.
As an alternative, I think the 240sx was a good suggestion. Also I think RX-8 prices have dropped into your range. If you can find one with a fresh engine, that could work as well.
Drives: 2013 GBS BRZ Limited
Miata, Porsche boxster, Porsche 914 (my current choice).
#10 |
Time Traveller
Miata is the only answer. Probably NB.
But if you REALLY don't want a Miata: Perhaps an MRS (underrated and forgotten, but very fast), Track built Ranger (pure project but can FLY), 350z (dubious reliability) 240 (a lot 240s are hunks junk by now though). An old Fiero could also work. Also look into BMW Z3s from the late 90s early 2000s. You might be able to score a Pontiac Solstice/Saturn Sky for 10-12k. RX8 and you'll be rebuilding the motor as regular maintenance, remember that. S2K and E36 M3 are out of that $7500 price range. |
#11 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Miata. I built my BRZ to take lapping and to auto x and decided I was so far into it I will just buy a Miata as well and make the BRZ my street car.
No sense risking $50k worth of car and mods. |
#12 |
Answer is most definitely Miata, and for me spec Miata is super attractive as Track days start to wear thin, spending half the time getting passed by V8's and Flat-6's with decent drivers and the other half passing them with slow drivers.
Also seriously thought about AW11, running NA beaters can be had for under $2k all day long (with issues though). I get the feeling that working on it can be frustrating and it's one of those projects that you could dump a ton of effort into and end up with not much but memories and some entertaining shenanigans. Something rarely mentioned: Honda Preludes and Integras are also dirt cheap with bulletproof powertrains and larger aftermarkets than AW11. Maybe Dave can chime in on his racecar... I know we all have hard-ons for RWD but when looking for cheap fun you're not going to get a ton of power, FWD can still do the trick. And worth noting if you get into AutoX FWD is seriously competitive on the right course. Edit: RX-8 is probably the best DD-able non-yacht RWD track capable car built in the last 15 years. But I think it'll be a better DD than Track car, they seem a bit soft stock so require a bit of $$$ to really maximize the grip it's capable of. Problem is in your budget you have to get a 2004-2006, the least reliable, stepping up to >2006 seems to be outside your budget ![]() RX-8 would be the perfect answer to "I have $10k and want a DD that I can have fun tracking occasionally with minimal work" |
#13 |
Drives: 86
330ci
Edit: oh wait, "track car". Miata, MR-S... also I see the E36 M3 under $7500 often, but those are usually nowhere in good condition enough to be put on the track. Last edited by juliog; 02-17-2015 at 02:07 PM. |
#14 | ||
Site Moderator
Drives: Stuff
I wouldn't be too concerned if it's just a roll bar vs a cage. I'd run a hardtop on any track Miata and the bar should be fairly high. Not ideal for sure, but not terrible. Quote:
![]() 350Z's are heavy pigs but decent on the track with the right mods. Any larger/heavier vehicle will have a higher consumable cost as well.
-Dave
| How many of you drive a lot ridiculous amounts? | mervingee | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 01-28-2015 04:02 PM |
| should i be worried about small amounts of knock? | Basket Case | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 04-21-2014 08:29 AM |
| 7500 mile service done. 30k will suck. | FRSpdDmn | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 08-09-2012 09:34 AM |
| 7500 mile review. | Superhatch | BRZ First-Gen (2012+) — General Topics | 16 | 07-23-2012 03:43 PM |
