Old 02-15-2015, 06:37 PM   #1
HGaudio
Drives: 13' Scion FRS
Need ecutek to dyno tune?
I've been looking into getting my frs dyno tuned but I am wondering if you need the ecutek software for them to be able to tune it at the dyno or it's just a kit to plug and play tune
HGaudio is offline   Reply With Quote
Old 02-15-2015, 07:19 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Welcome to the forums.
There is a LOT of info on this on these forums if you look at the stickies and do some searching. There are 3 main tuning solutions available for an 86/BRZ/FRS, Ecutek, OFT and BRZedit. Each has their pros and cons. I suggest you talk to you tuner and find out his preference.
1974 TA22 Celica
2013 86 GT
Old 02-15-2015, 07:46 PM   #3
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
To dyno tune, you need something that will edit the ECU as well as a tuner that is familiar with working with it.
EcuTek is popular because many dyno tuners are already using it.
Another option, and probably better suited for you unless you're going custom FI, is to just get an off the shelf tune. EcuTek and OFT both provide off the shelf tunes for whatever your application may be.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-15-2015, 09:48 PM   #4
burdickjp
Drives: 2013 ultramarine Scion FR-S
The Tactrix Openport 2.0 is very capable piece of hardware which is not software-tied.
burdickjp is offline   Reply With Quote
Old 02-18-2015, 09:26 AM   #5
nickw14
Drives: Built FA20
Correct me if I'm wrong, but most tuners already have their own software/hardware don't they?
nickw14 is offline   Reply With Quote
Old 02-18-2015, 10:19 AM   #6
robr
Drives: 2013 FRS, with boost by ATS Racing
If they've done a few FRS/BRZ tunes, and plan to do more, they probably have an ECUtek cable and software, yes. You still have to buy a license from someone, whether from your tuner or someone else. So you still have to pay the $300 or whatever license cost PLUS whatever your tuner charges for the actual tune.
If they use some other tuning package, same deal (assuming whatever they use needs a license/key as well).
As always, it is best to talk to your tuner BEFORE you start buying stuff. They might work on you with pricing if you get everything from them at the same time, they will tell you what they are most comfy with, etc.
robr is offline   Reply With Quote
Old 02-18-2015, 12:36 PM   #7
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
For better or worse, the only "plug and play" tuning device for the FRS/BRZ is the OFT
Meaning that all you will use is the OFT to write a tune to your ECU. No need for a laptop/extra cabling/software licenses. This device also allows you (or your tuner) to apply custom dyno tuning changes using free software (RomRiader) that you and download off the website. In addition to that the OFT allows for on-board datalogging, digital dash displays, user configurable tuning alerts and diagnostic functions.
Ecutek is a completely different product and its worth doing some research to see if it meets your needs.
Cheers,
shiv
CEL issue after dyno tune reyruiz191 Software Tuning 10 07-29-2016 08:50 PM
Need a dyno tune in sydney brz961 AUSTRALIA 10 06-19-2016 07:57 AM
Dyno Tune in SoCal Cal3000 Southern California 11 09-03-2013 01:03 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
Dyno tune near CNJ? Craig NY / NJ / CT / PA 2 01-31-2013 06:57 AM
