Old 02-13-2015, 04:36 PM   #1
HachiRo
Drives: 2013 White-Out FRS
Cutting Stock Exhaust Into Single Exit?
Had a random thought today. If I were to cut the stock exhaust and weld on a pipe making it look similar to the Nameless or Berk Track Pipe exhaust, would the tone be the same? It'll basically be the same shape and size..
HachiRo is offline   Reply With Quote
Old 02-13-2015, 07:25 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Yea it will sound the same since you are deleting mufflers. The Berk muffler delete I have is 2.5 inches..the factory iirc is 2.25..so diameter will be off by .25 inches.
Old 02-13-2015, 07:28 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
You wanna cut behind the muffler? Basically run straight after the mid pipe?
Old 02-14-2015, 04:28 AM   #4
HachiRo
I wanna cut like right at that little curved piece right before the muffler starts, so the on the pipe after the midpipe before it goes into the muffler itself.
Old 02-14-2015, 04:29 AM   #5
HachiRo
Think that would make it deeper or less?
Old 02-14-2015, 11:04 AM   #6
dem00n
dem00n's Avatar
Drives: Scion FRS
It would be a muffler delete. Just google Berk muffler delete.
Old 02-14-2015, 02:04 PM   #7
HachiRo
I'm aware of that, did you read my initial post? Haha I'm asking if I cut it instead of buying the Berk, would it be the same.
Old 02-14-2015, 03:24 PM   #8
NyC Zn6
NyC Zn6's Avatar
[ame]http://youtu.be/diHcsp47Emw[/ame] . Here is my car with just a muffler delete to give you an idea.
Old 02-14-2015, 09:24 PM   #9
HachiRo
Thanks!
Another project teaser. Exhaust hole covers for single exit exhaust! Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 57 05-30-2014 01:46 AM
single exit exhaust jdmblood Engine, Exhaust, Transmission 24 09-07-2013 04:27 PM
For Those of Us with a Single-Exit Exhaust naikaidriver Engine, Exhaust, Transmission 12 09-05-2013 01:20 PM
Single exit exhaust? Sonydigital Engine, Exhaust, Transmission 24 07-20-2013 11:26 PM
Stock Exhaust to Single Exit DriftEightSix Engine, Exhaust, Transmission 3 02-16-2013 10:48 PM
