Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
Cornering
I've noticed on sticky PSS tires when I corner vigorously the back end feels like it's wobbling/hopping around and basically feeling unsettled. This is usually at speeds where the stock tires will start to squeal (35mph+).
What kind of suspension upgrades would I need to improve this? Stiffer springs/coils? Swaybars? Stiffer bushing? |
#2 | |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
get better suspension, you wont regret it
I just bolted on a ohlins kit for my e46 and am pretty impressed, bet the one for 86 is as nice
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
| The Following User Says Thank You to kiichiro For This Useful Post: | enouf (02-13-2015) |
#4 | |
Drives: 2013 Ultramarine FRS
That being said, I am no pro driver or pro mechanic or pro anything. Just tossing input. |
| The Following User Says Thank You to Add3r For This Useful Post: | enouf (02-13-2015) |
#5 | |
Mr. Grumpy
I've noticed if I do the same thing with stock tires, the car remains smooth but with stickier tires it becomes unsettled. I was thinking it was due to the stickier tires (and maybe higher speeds) emphasising the movements in the suspension. |
Drives: 2013 BRZ Limited
Absolutely could be driver technique. With stickier tires you are actually probably turning in harder then with the stock tires. Just try to turn in smoother, if the road allows it start slightly wider.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
| The Following User Says Thank You to CoupedUpSubie For This Useful Post: | enouf (02-13-2015) |
#7 | |
You may also want to look at all the other factors as stated. Also, unsettling may mean you're also traveling at a higher pace than before. Keep in mind, the speeds can be different as well. Driver skill ranks above all. The driver's ability to take advantage of the tire compound is what driving is all about. You can't rely on equipment to always let you go fast. |
#8 | |
| The Following User Says Thank You to Koa For This Useful Post: | enouf (02-13-2015) |
The stock car is much better than many suspension kits out on the market. Driver mod is very important but also learning about what the capabilities of the factory vehicle is also equally important. Toyota/Subaru didn't throw millions of dollars just to be outdone by a company that tossed $500 suspension at the car and said it's better than factory.
#10 | |
Drives: Whiteout Scion FR-S
How many miles (or kilometers) are on the car? If quite a few, it would be worth checking the rear shock absorbers. My are shot after only 40,000 miles.
| The Following User Says Thank You to Black Tire For This Useful Post: | enouf (02-13-2015) |
#11 | |
Mr. Grumpy
Car's only done 10,000 miles (weekend toy) so I don't think it's the shocks. I'll save up the money and work on driver mods. It makes sense that with stickier tires I'm pushing it way harder than when it was on stock, and in the process being too aggressive with my inputs. I'll do more experimenting with the stock and PSS tires and see how it goes. |
| Why you need a LSD if you like cornering! | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 342 | 08-24-2019 10:08 PM |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 09:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 08:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 09:40 AM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 01:49 PM |
