Old 02-12-2015, 05:57 PM   #1
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Cornering
I've noticed on sticky PSS tires when I corner vigorously the back end feels like it's wobbling/hopping around and basically feeling unsettled. This is usually at speeds where the stock tires will start to squeal (35mph+).
What kind of suspension upgrades would I need to improve this? Stiffer springs/coils? Swaybars? Stiffer bushing?
enouf is offline   Reply With Quote
Old 02-12-2015, 06:15 PM   #2
CSG David
CSG David's Avatar
Change your driving habits, alignment, play with tire pressures, and report back. Once you figured out how the car responds to these different inputs and you have maximized the capability of those, then you'll have a better idea of what you're looking for for your application.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
bedabi (02-16-2015), enouf (02-13-2015), Koa (02-13-2015), Pat (02-12-2015)
Old 02-12-2015, 06:52 PM   #3
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
get better suspension, you wont regret it
I just bolted on a ohlins kit for my e46 and am pretty impressed, bet the one for 86 is as nice
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
enouf (02-13-2015)
Old 02-12-2015, 09:00 PM   #4
Add3r
Drives: 2013 Ultramarine FRS
+1 to this. Was told to never throw parts at problems such as this, but to instead embrace it and change the way you drive the car. Just throwing parts at this situation could only compound the problem IMO, and does not fight bad habits. Not saying this is a bad habit, but merely a change in dynamics meaning your driving style must reflect it.
That being said, I am no pro driver or pro mechanic or pro anything. Just tossing input.
Add3r is offline   Reply With Quote
The Following User Says Thank You to Add3r For This Useful Post:
enouf (02-13-2015)
Old 02-12-2015, 09:04 PM   #5
enouf
Mr. Grumpy
enouf's Avatar
So it could be driver technique? Smoother inputs?
I've noticed if I do the same thing with stock tires, the car remains smooth but with stickier tires it becomes unsettled. I was thinking it was due to the stickier tires (and maybe higher speeds) emphasising the movements in the suspension.
Old 02-12-2015, 09:20 PM   #6
CoupedUpSubie
Drives: 2013 BRZ Limited
Absolutely could be driver technique. With stickier tires you are actually probably turning in harder then with the stock tires. Just try to turn in smoother, if the road allows it start slightly wider.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
enouf (02-13-2015)
Old 02-12-2015, 09:29 PM   #7
CSG David
CSG David's Avatar
With "stickier" tires per say, the time it "wipes out" is much shorter than with less sticky tires. The limit before adhesion is lost is much higher, but the amount of time to cross the limit to completely sliding is much less.
You may also want to look at all the other factors as stated. Also, unsettling may mean you're also traveling at a higher pace than before. Keep in mind, the speeds can be different as well.
Driver skill ranks above all. The driver's ability to take advantage of the tire compound is what driving is all about. You can't rely on equipment to always let you go fast.
bedabi (02-16-2015), dp1 (02-12-2015), enouf (02-13-2015), Koa (02-13-2015)
Old 02-13-2015, 02:39 PM   #8
Koa
100% why I faceplam whenever people change out sways as their first suspension mod. Especially ridiculous track setups thinking they can still DD it nicely or to "combat bodyroll"
The Following User Says Thank You to Koa For This Useful Post:
enouf (02-13-2015)
Old 02-13-2015, 04:17 PM   #9
CSG David
CSG David's Avatar
The stock car is much better than many suspension kits out on the market. Driver mod is very important but also learning about what the capabilities of the factory vehicle is also equally important. Toyota/Subaru didn't throw millions of dollars just to be outdone by a company that tossed $500 suspension at the car and said it's better than factory.
The Following 5 Users Say Thank You to CSG David For This Useful Post:
Add3r (02-13-2015), bedabi (02-16-2015), enouf (02-13-2015), JB86'd (02-13-2015), Koa (02-13-2015)
Old 02-13-2015, 04:31 PM   #10
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Did you observe this behavior with all of the electronic controls enabled? If so, you should try the same maneuver with the traction control and VSC shut off. These systems can apply the rear brakes one at a time which could result in the conditions you describe. Better yet, since the console button never totally disables this system, do the pedal dance and then test the car again.
How many miles (or kilometers) are on the car? If quite a few, it would be worth checking the rear shock absorbers. My are shot after only 40,000 miles.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
enouf (02-13-2015)
Old 02-13-2015, 08:20 PM   #11
enouf
Mr. Grumpy
enouf's Avatar
I avoid driving on public roads without the nannies on and I don't see the traction light come on when carrying out the cornering. There's one turn that I always experience this so I'll probably try it with VSC sport to see if it makes any difference.
Car's only done 10,000 miles (weekend toy) so I don't think it's the shocks.
I'll save up the money and work on driver mods. It makes sense that with stickier tires I'm pushing it way harder than when it was on stock, and in the process being too aggressive with my inputs. I'll do more experimenting with the stock and PSS tires and see how it goes.
The Following 2 Users Say Thank You to enouf For This Useful Post:
Add3r (02-13-2015), N234 (02-13-2015)
Why you need a LSD if you like cornering! CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 342 08-24-2019 10:08 PM
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 09:04 PM
cornering-on-rails feeling notout86 Scion FR-S / Toyota 86 GT86 General Forum 38 09-20-2015 08:00 PM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 09:40 AM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 01:49 PM
