Old 02-10-2015, 09:01 PM   #1
r1concepts
r1concepts's Avatar
Stoptech, Brembo, AP Racing, Performance Friction, K-Sport BBK Comparison
Just thought I'd share an article posted on Stoptech's site today regarding their kit vs. other competitors BBK's such as AP Racing, Brembo, Performance Friction, and K-Sport. It's a comparison between these kits and interested to see that Stoptech won in every category according to their testing. Enjoy!
Autobild Magazine (German Magazine)
http://www.stoptech.com/media-center...omparison-test
r1concepts is offline   Reply With Quote
Old 02-11-2015, 02:52 PM   #2
ThreeEyedCrow
ThreeEyedCrow's Avatar
Drives: Scion FRS
That test was specific to a BMW M3 though. Nothing 86 related at all. Interesting read though. It'd be cool to see a third party review of all the bbk's for this platform.
ThreeEyedCrow is offline   Reply With Quote
Old 02-11-2015, 05:07 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
So StopTech won but the article is posted by StopTech on their site. Maybe they are in cahoots...
I'm surprised to see Brembo dead last, I would have though K-Sport was worse.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-11-2015, 05:59 PM   #4
Racecomp Engineering
There's a great thread on the EVO board about how awful D2/Ksport brakes are for everything. Nothing can be worse and I would not allow them on my car.
Seems like there must have been something up with that Brembo kit...the regular GT kit isn't amazing and I'd probably put AP, PFC, and Stoptech on par or ahead but they aren't bad IMO.
- Andy
Old 02-11-2015, 06:07 PM   #5
DAEMANO
Time Traveller
Test looked legit to me. Autobild is no joke when it comes to testing about anything. Thorough. http://www.autobild.de/videos/video-...--5416738.html
I'd also like to see a comparison on the '86 platform. Good showing for StopTech. Especially on the repeated hammering 20 stop test. This was an expensive kit that was test 3,700 Euros, but far from the most expensive kit in the test (those were the crap peforming Brembos at 4,400 Eur). Also the AP kit did well too for under 4k Euros. They should be proud.
Old 02-11-2015, 08:47 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Am I missing it? What pads were used?
Quite an interesting test/writeup regardless.
Old 02-16-2015, 09:33 AM   #7
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
A couple of thoughts from an insider viewpoint:
  • The article is based around track performance. My first question is: Why would they take a group of street big brake kits and test them on the racetrack, rather than evaluating each of the manufacturers' best available track brake kit (StopTech Trophy, AP Racing Competition Kit (either the AP Racing Factory one or our Essex one), a Brembo GT-R kit, etc.)? I'm assuming it's because the BBK's in the article are the only ones that are currently TUV approved? Street performance and track performance are evaluated under an extremely different set of criteria. Street performance is about pedal feel, seamless ABS interaction, Noise/Vibration/Harshness, and cosmetics. Track performance is about fade resistance, disc, pad, and caliper temperatures, component weights, available pad options, pad and disc wear rates, iron disc replacement costs, wheel fitment, etc. Excelling in one arena doesn't typically mean being the top of the heap in the other. If you're going to look at track performance by brand, it would make sense to put each manufacturer's best foot forward for the competition.
  • Pads are a critical piece of the puzzle, and variable elimination is at the core of the scientific method. My understanding is that the same pads were not used in all of the kits (you can see different color pads in the various calipers). To make the comparison as apple-to-apples as possible, it definitely would have been best to run the same pads in all kits. I can understand why they didn't use the same pad compound in each kit, but it is a variable that does unfortunately impact the results rather dramatically. Anyone running one of these kits their M3 on a track in Germany can easily toss the pads that came with their kit and likely get Pagid race pads at a reasonable price (Pagid is a popular brand in that region). As such, it seems a bit silly to insist that the pads remain "as delivered." Yes, I know that the pads are considered part of the approved kit in Germany, but I also know that people will run what they need to run on the track.
· That said, the magazine was working with what they were given, within the as-delivered specs including TUV approval (which is crucial in Germany). I'm sure the magazine editors also didn't want to add to an already costly test by spending an additional $2400 to buy identical race compounds for all of the kits in the various shapes (6 kits x $400 per pad set). It still seems like a very big missed opportunity to me.
· Comparing a street or semi-street hybrid pad against a track pad is a big no-no. Their characteristics are dramatically different (see my article on How to Choose Brake Pads). The FM1000 that ships in a Brembo kit is a slightly milder version of Ferodo DS2500. Pagid RS29 is an endurance racing compound. They're not even remotely similar.
  • As some others have mentioned, stopping distance is largely a function of tire choice. Using the same tires on all was an excellent choice. One would expect any solid aftermarket street BBK to have a similar or slightly better stopping distance than OEM under a one stop scenario. The Brembo results are definitely surprising in that regard. Again though, pad friction level when cold has an influence on this result, but the FM1000 pads in that kit should have good cold bite.
  • Now I'm not sure if I'm reading the data correctly, but it looks like every brake kit tested, including OEM, had very little fade over 20 stops from 200-0 kmph. The 20th stop on each was roughly within a meter of their first stop distance. That means none of them, including stock, exhibited any noticeable pad fade. The comments about the soft pedal on the OEM option indicates fluid fade. If I was analyzing the data for the article as presented, it would have been a single sentence article, "If you never plan to do anything more than 20 stops from 200 kmph, don't waste your money on a BBK!" Some of the kits showed a shorter 20th stop vs. the first, which is likely because the race pad compounds generate more mu with some heat in them.
· What they should have done first is to find the 'failure point' of the OEM system. If the OEM system wilted on the 27th stop from 200 kmph, adding 20 meters to the stopping distance, then from that point 'up' (more stops and/or from a higher speed) would have been the critical info to gather on the big brake kit stopping distances relative to stock and each other.
· To take this a step further…run each big brake kit until it wilts from overheating, be it pad fade or fluid fade. That would show how much torture each could take, and would give a better understanding of their value vs. the OEM brakes, their relative durability to each other, and a better approximation to the stresses inflicted upon your brakes at the track.
  • Taking disc temps would have shown how cool the discs were running after the series of stops. This could have been done with a pyrometer at the end of the stop, or for more accuracy, on-board via a thermocouple with data-logging (very simple with today's data acquisition…pedal travel and pressure can also be measured in that manner). Disc operating temps are critical when evaluating the efficiency of a brake kit (how much air the discs flow), pad and disc wear rates, the impact on the caliper and brake fluid temps, and the resulting likelihood of boiling that fluid. Without temps, you don't really know which kit is working best or smartest, or which is likely to last longest.
  • They could have taken a look at the discs in each kit after the test to evaluate heat checking/cracking, as well as pad wear (how many mm of pad remain, any taper, etc.). Again, that would give some great insight into how durable each kit is, and what a user could expect.
  • The weight of separate components should have been measured. Two kits may weigh the same, but one may have far more thermal mass in the disc, while the other is toting around four extra, unneeded lbs. in the caliper. The complete corner weight doesn’t mean much without knowing where that weight is!
  • How much do spare iron rings cost? How much do replacement race pads costs? Are there a lot of pad options for each kit? Does each kit fit the most common track wheels people are using? These are some of the most important questions when evaluating an aftermarket big brake kit.
Overall, I wouldn't go so far as to completely throw this evaluation under the bus, but I don't know how much valuable data actually lies within it. As far as I can tell we're looking at street big brake kits being tested for stopping distances under moderate usage conditions that barely even exceed the stock brake system's capacity. In such a case, feel and aesthetics will be the primary differences between kits, which are both somewhat subjective.
JRitt is offline   Reply With Quote
Old 02-16-2015, 09:29 PM   #8
r1concepts
r1concepts's Avatar
I understand what you're saying. Just wanted to clarify that I am not saying that a Stoptech BBK is the best BBK on the market even though I am a distributor of their products. I am also a distributor for Brembo products as well. It was interesting read I came across on their site the other day and thought I'd share for anyone who is/are interested in a BBK that's popular on the market today.
Old 02-17-2015, 02:36 PM   #9
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
This test doesn't really say anything conclusive besides what each set costs!
Hoosier Daddy is offline   Reply With Quote
Old 02-17-2015, 02:45 PM   #10
Dezoris
Dezoris's Avatar
[quote]@Jritt Pads are a critical piece of the puzzle, and variable elimination is at the core of the scientific method. My understanding is that the same pads were not used in all of the kits (you can see different color pads in the various calipers). To make the comparison as apple-to-apples as possible, it definitely would have been best to run the same pads in all kits. [/quote]
It's really as simple as that, if you can't run the same pad compound on each brake kit it's basically pointless to compare.
Old 02-19-2015, 08:54 PM   #11
Pads are a huge part of it...but sometimes a brake kit is just awful crap.
See this D2 BBK (which is I believe similar to K Sport):
http://www.evolutionm.net/forums/evo...-shacking.html
- Andy
Gotta Stop with Brembo or Stoptech BBK w/ Special Pricing!!! Titanmotorsports Brakes, Suspension, Chassis 37 03-15-2016 10:33 AM
Brembo: GT, GT-R, Club Sport Brakes, AP Racing BBK & Agency Power Brake & Clutch Line eauto Brakes, Suspension, Chassis 361 10-15-2014 01:43 PM
Gotta Stop with one of these Brembo or Stoptech, Hawk Titanmotorsports Brakes, Suspension, Chassis 0 07-11-2013 07:11 PM
AP Racing CP8350 (Essex Sprint kit) vs Stoptech ST40 Comparison CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-17-2013 03:41 AM
Stoptech Sport Brake Kit goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-28-2012 06:57 PM
