Old 12-23-2012, 08:03 PM   #1
goke186
Stoptech Sport Brake Kit
I recently purchaced and had my Stoptech brake kit installed and noticed that there is an excessive amount of brake pedal travel over stock. I am using Motul 600 brake fluid and the system was bled 6 times. Anyone else notice this or have this type of issue?
Thanks!
FIVE AXIS DESIGN http://www.fivead.net (FIVE:AD Edition Ultramarine FR-S)
VTR http://vtrweb.com/ (Reccomended Pacific NW Shop!) [CLOSED]
AVO Turbo http://www.avoturboworld.com (Great Products for a Great Price!)
goke186 is offline   Reply With Quote
Old 12-23-2012, 10:22 PM   #2
orthojoe
Is the pedal endpoint still firm? If it is, then the increased pedal travel may be secondary to the master cylinder being too small for the larger calipers?
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 12-24-2012, 03:00 AM   #3
goke186
calipers are OEM, the kit replaces the brake lines, rotors, and pads
Old 12-24-2012, 03:17 AM   #4
#87
I usually post drunk
#87's Avatar
Maybe the pads are higher temp? I remember the first time I did a pad change I went too aggressive and they were not as good cold but rock hard when warmed up.
#87 is offline   Reply With Quote
Old 12-24-2012, 03:38 AM   #5
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
What do you consider excessive? Is there any noise or anything that would point to shims not being installed?
JoeBoxer is offline   Reply With Quote
Old 12-24-2012, 08:37 AM   #6
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Flip the calipers let to right if the bleeder is at the bottom
Sent from my iPad using Tapatalk HD
RWD-boxer is offline   Reply With Quote
Old 12-24-2012, 08:53 AM   #7
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
If the pedal changed and the calipers were not changed, then it is due to an improper flushing/bleeding of the system. We've been installing brakes for 12 years and we've fixed so many "installs" over the years.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 12-24-2012, 09:15 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
-Mike Paisan
This.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-25-2012, 12:26 AM   #9
goke186
Hard to actually put a number on it or comparison, all I have to compare the new lines, pads, rotors, and fluid is the stock set up.
The stock set up was very responsive and took very little pressure on the pedal for the brakes to engage and grab, now it feels like the travel and pressure required to get the brakes to engage has at least doubled.
Once the brakes grab they are very strong and do not feel spongey, if i pump the pedal twice then the brakes grab quickly(much closer to stock feel).
Old 12-25-2012, 12:27 AM   #10
goke186
-Mike Paisan
That's what I was thinking, along with most of my friends lol
Old 12-25-2012, 12:38 AM   #11
orthojoe
How much have you driven it? A brand new set of pads/rotors will initially feel pretty bad until you use them a few times. You should bed them in too.
2013 Subaru BRZ
Old 12-26-2012, 02:43 AM   #12
goke186
bed them in? sorry, never really have had performance brakes... i havent driven on them very long.
Old 12-26-2012, 03:09 AM   #13
OrbitalEllipses
Drives: Attitude
Bedding in new pads/rotors is very important. Here's some info: http://www.essexparts.com/learning-c...rs/post/Bed-in
Old 12-26-2012, 09:33 PM   #14
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
It is also VERY dependent on What order you Bled... You should always do the farthest away from the MC first down to the shortest..
Bill
Scooby South is offline   Reply With Quote
Stoptech Sport Brake Kit blkwrxwag Brakes, Suspension, Chassis 9 12-08-2012 03:05 PM
Special on New StopTech Sport Brake Kits for FR-S and BRZ PRO Import Tuners Brakes, Suspension, Chassis 17 08-29-2012 10:27 PM
StopTech Brake Kit for the FR-S / BRZ Drift-Office Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 08-24-2012 02:36 AM
StopTech Introduces Sport Kit Brake Upgrades!! vividracing Brakes, Suspension, Chassis 0 06-27-2012 02:41 PM
