Old 02-10-2015, 06:56 AM   #1
FRSPhil
Nobody Epic
FRSPhil's Avatar
Drives: 2014 WRX SWP
FRS HID problem "surprise right?"
Just recently got a 2013 FRS used but only 14k miles. First time driving late at night I flipped on what I thought was my dims, but after getting flashed my numerous cars I decided to investigate what it was they were getting upset for. Discovered that my dims are actually my brights. So I tried flipping my my brights on to discover that it was actually my dims that would turn on for my brights. So everything is ass backwards. Did a little research and a little guide said switching the polarity would fix it. Big surprise that didn't even work instead my dims wouldn't even work when I done that. Guess I can speak for some people when I say switching the polarity is too good to be true. I've never really even messed with HID till I got the FRS. So anyone with great expertise and knowledge that could recommend a fix or replacement would be greatly appreciated. Haven't had time to really look at the name brand kit or bulbs currently in it. When available I'll take a closer look into it. Thanks!
FRSPhil is offline   Reply With Quote
Old 02-10-2015, 12:24 PM   #2
8R6
8R6's Avatar
Drives: FRS
hows that even possible with an HID kit? aftermarket HID kits for our cars (non-bixenon) is essentially just a headlight bulb swap. Our highbeams are the same as our DRL halogens and is a separate bulb from the lowbeams...
8R6 is offline   Reply With Quote
Old 02-10-2015, 12:35 PM   #3
FRSPhil
Nobody Epic
FRSPhil's Avatar
Not exactly 100% sure what the previous owner did. Me being new to this assumed that my headlights (HID) are always really bright. Wish I knew how to explain it better but I'm really a novice to this.
Old 02-10-2015, 05:53 PM   #4
kbye
kbye's Avatar
Drives: 2014 FR-S
To clarify, when you turn on your low-beams, which part of the headlight lights up? The outside projector or the inner bulb? If it's the inner one, you got some wiring issues.
kbye is offline   Reply With Quote
Old 02-10-2015, 06:00 PM   #5
jeffwilliams
Drives: 2014 Asphalt FRS
Your low beams are the outside projector lense. The inner light in the reflector housing is drl/high beam. Have a look at the stalk for the lights, if it is pushed forward the high beams will stay on. Try pulling it back and see if the high beams go off.
jeffwilliams is offline   Reply With Quote
Old 02-10-2015, 06:57 PM   #6
FRSPhil
Nobody Epic
FRSPhil's Avatar
When I turn on low the inner bulbs come on and when I hit the high beams on the outer turn on
Old 02-10-2015, 06:59 PM   #7
FRSPhil
Nobody Epic
FRSPhil's Avatar
I'll have to give it a try once I get home. Greatly appreciate it.
Old 02-10-2015, 10:14 PM   #8
KI_ZN6
KI_ZN6's Avatar
On the FR-S, the projector lens are the low beam driving lights. The inner bulb is for the daytime running lights and high beams.
It is possible to have the low beam and high beams on all together if you have the turn signal stalk pushed towards the dashboard, activating the constant high beam "on" mode. Should be a relatively simple fix
KI_ZN6 is offline   Reply With Quote
Old 02-11-2015, 10:51 AM   #9
FRSPhil
Nobody Epic
FRSPhil's Avatar
Only conclusion I've come to so far is previous owner didn't know how to do wiring. I've done every single combination with the wiring and still no fix. Think it would be safe for me to say that I'll just replace the bulbs and wiring myself and save myself the heartache.
Old 02-11-2015, 11:13 AM   #10
kbye
kbye's Avatar
Drives: 2014 FR-S
The only other thing I can think of is that the previous owner connected the HID kit into the low beam wiring but plugged the HIDs into the hi-beam location. If that's the case, then as long as you buy the correct bulb sizes and swap them around then it should be an easy fix. You will need H11 HID for lo-beam and HB3 for DRL/hi-beam.
Old 02-11-2015, 11:17 AM   #11
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
My thoughts...
HID were wired to trigger off the high beam signal, not the low beam signal. This means nothing other than which signal turns on your HIDs. Just need to switch the signal wire to the correct one, this is probably on the adapter harness.
As for the beams blinding other people, you most likely just need to adjust your headlights downward via the adjustment screws. previous owner probably adjusted them up like a moron.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-11-2015, 11:25 AM   #12
FRSPhil
Nobody Epic
FRSPhil's Avatar
Originally Posted by aznatama View Post
My thoughts...
I figured since their screw up that making the beams upward would solve it. Thanks for the reply.
Old 02-11-2015, 11:27 AM   #13
FRSPhil
Nobody Epic
FRSPhil's Avatar
Do I need to specifically get these bulbs from a dealer or will a local shop have them?
Old 02-11-2015, 11:45 AM   #14
kbye
kbye's Avatar
Drives: 2014 FR-S
You can buy the normal bulbs at any parts store.
Do you have pics or diagram of the wiring? It might be easier to help you that way. For example, since you mentioned the low-beam HIDs are in the hi-beam location, it could have meant that he bought an HB3 (9005) HID kit and modified the ballast harness to connect to the H11 connectors. OR, he could have also bought an H11 HID kit and spliced in an HB3 bulb. Or my theories could be completely off, lol.
Best bet is to tear the HID kit out and utilize the stock wiring with normal bulbs in its proper locations. Then you can look at properly retrofitting HIDs later down the road. Good luck.
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
