Old 02-08-2015, 02:44 PM   #1
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Manzo Header (Under $300 header?)
I've been researching headers because apparently they are all the rage now for our cars, giving the best gains in power especially with a tune...
There are LOTS of options out there which is pretty crazy, considering how few there were for Normally Asperated Subaru's prior to the BRZ/FRS (My previous car was a EJ25 N/A Impreza, and I had 3-4 different headers/exhaust setups on my N/A Imprezas I owned, so I have some experience with N/A boxer exhaust systems)
I really like the results I've seen from the HKS headers and other EL headers. The boxer rumble from the OFH and Borlas are very nice, but I've done that before so not a huge deal. But the price points of headers varies SO MUCH, from ~$500 to $1500 for some of the really good systems (that Ace 4-2-1 header/OP combo makes me go hnnnnnnng)
But anyway, I found the Manzo Headers on a couple websites, and they appear to be clones of the HKS setup, and some folks have mentioned them here but I haven't seen any reviews:
http://www.jonmotoring.com/frs-brz-m...length-header/
http://www.frsport.com/Manzo-TP-215-..._p_230803.html
For well under $300, I could buy these AND get an Openflash Tablet for the cost of some of the "quality" systems out there...
I've delt with poor fitting headers before too (early Borla EJ headers were horrible in terms of fit and finish) so I can deal with that, I would probably coat them with high-temp paint just in case for rust prevention.
I guess the question is, should I or shouldn't I?
At the very least, we will have a thread about these headers now... LOL!
Kostamojen is offline   Reply With Quote
The Following User Says Thank You to Kostamojen For This Useful Post:
Teseo (02-08-2015)
Old 02-08-2015, 03:05 PM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
i would not suggest to buy them. if your looking to save some money instead of buying the OFH, try the Tsudo header. I am running it with the OFT Stage 2 tune and am very happy with it.
http://www.semotors.com/tsudo-2013-s...length-header/
malubawla is offline   Reply With Quote
The Following User Says Thank You to malubawla For This Useful Post:
Whatabouteggs (02-08-2015)
Old 02-08-2015, 03:06 PM   #3
swarb
Why or why not?
Old 02-08-2015, 03:07 PM   #4
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Those headers are basically stock manifolds with a front cat delete. The collector outlet is 2.25" which is also stock size. Aside from whatever you would gain from deleting the cat, I don't think this header would provide any meaningful benefit.
That being said I would also be wary of the same problems you'd find with ebay headers; broken welds, pieces of metal coming loose inside the header after install that ruin cats or turbos, sub-standard metal that corrodes or rusts through after a couple years, etc.
Quality parts are very expensive for these cars, unfortunately there are reasons for that.
EDIT: I do like tsudo's stuff though, provided you can actually find it.
Whatabouteggs is offline   Reply With Quote
The Following 2 Users Say Thank You to Whatabouteggs For This Useful Post:
malubawla (02-08-2015), raven1231 (08-03-2015)
Old 02-08-2015, 03:10 PM   #5
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
the primary runners on many of the cheaper headers are 1.5" and the outlet is 2.25". OFH, Tsudo, Revworks etc headers have runners that are around 1.61" and also a 2.5" outlet. you would gain some powers from the cheaper header, but you might as well just run the stock header with the cat gutted out then.
Old 02-08-2015, 04:01 PM   #6
Kostamojen
That is good info right there.
There is another header like this thats cheap but not AS CHEAP (Godsnow?) that showed reasonable gains but not as much as other headers probably due to the deletion of the cat.
Old 02-08-2015, 04:30 PM   #7
jonbonazza
I'd be more worried about the fitment/weld quality over the size of the runners, thb.
For example, the DC Sports header has terrible fitment (Read: it never fits right) and the Borla header has terrible fabrication quality. Welds that break easily, half-assed collectors, etc..
jonbonazza is offline   Reply With Quote
Old 02-08-2015, 08:02 PM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Again with the borla hate, those were only issues with the first batch of them.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 02-08-2015, 08:03 PM   #9
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
+1 for the Tsudo UEL header.
I'm also running it with OFT stage 2 tune and am very happy with the results. I think it was $350 or so when I bought it, its now being sold for $450 on semotors.com. The price has kept creeping up since before I bought mine at the end of the summer. Its very nice quality and perfect fit. Rumbles alone are worth it...the power is definitely nice too.
Old 02-08-2015, 08:08 PM   #10
Teseo
Drives: frs
I did not know Borla have those issues, i only heard good compliments.
Anyone with Borla headers (actually installed in the frs/brz) can chime in?
Old 02-08-2015, 08:16 PM   #11
Kostamojen
As I said, 15 years ago with the N/A EJ headers they had horrible cracking issues and fit issues. So its not a new complaint.
But those things are mostly irrelevant, if you take it to any muffler shop with a welder they can fix it for like $20-40.
Old 02-08-2015, 08:20 PM   #12
WolfsFang
Scrape Master
WolfsFang's Avatar
I've had the borla header in my car for almost a year and they are 100% fine, as I said those issues were only present in the first batch of them. My flanges were 100% flat, welds are still great and my collectors looked normal.
The Following User Says Thank You to WolfsFang For This Useful Post:
Old 02-08-2015, 08:41 PM   #13
Teseo
Drives: frs
So you have it yet? You will recomended to anyone
Old 02-08-2015, 08:44 PM   #14
WolfsFang
Scrape Master
WolfsFang's Avatar
Yes I would recommend borla headers to anyone. I bought mine for 300 used, love the rumble you get from these.
Sent from my XT1060 using Tapatalk
Teseo (02-08-2015)
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
