Old 02-07-2015, 10:44 AM   #1
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
will I notice a difference?
Hi, currently have lighter than stock rims weighing 17.2 lb each. Looking to get an even lighter set of rims that weigh 14.5. Stock wheels way 20. Something for reference. Do you think in will notice a difference in response, acceleration etc with these even lighter rims? When I dropped from the stock to these 17.2 weight their was a change for sure. Thx
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 02-07-2015, 03:49 PM   #2
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
I changed to 3 piece wheels and didn't notice anything, but then again I just street drive and never on the track. Maybe then there will be a difference
Instagram: 8as6
CyberAkuma is offline   Reply With Quote
Old 02-07-2015, 04:04 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
take your spare tire out of the trunk and see if you can feel a difference.
The Following User Says Thank You to stugray For This Useful Post:
BlueDubbinTDI (02-09-2015)
Old 02-07-2015, 04:49 PM   #4
raven1231
That's not even close to the same thing...
Old 02-07-2015, 05:10 PM   #5
stugray
Oh! So you have done the experiment! Cool.
However you are right.
Shedding 10.8 lbs from the wheels versus shedding > 15 lbs from the trunk are NOT the same.
Removing the spare will make a BIGGER difference.
However I still contend that the driver will not FEEL a difference under either option (hence why I said to do the experiment).
Now - will an experienced driver, on a track, with a datalogger be able to detect the difference between stock rims and rims that weigh 2.7 lbs lighter (using the data)?
Maybe.
How about this experiment: Could a driver (on the street) be able to tell the difference in handing from a set of tires with 20,000 miles on them versus 40,000 miles?
Because that is probably the difference of ~3 lbs per wheel in lost tread....
Old 02-07-2015, 06:31 PM   #6
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Unsprung weight make a lot more difference than sprung weight. There's also rotational mass involved with accelerating and braking. losing 10lb unspring weight will make a lot more of a difference than removing your spare for sure.
However, wether you can feel it or not... if you could feel the difference between stock and your current wheels, provided tires were the same weight, then yes, you'll feel a difference going lighter. However, be aware of wheel strength.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-08-2015, 12:21 AM   #7
swarb
you would be dropping weight with the wheels and adding it back on with heavier tires. since the weight is towards the outside diameter, it would actually "feel" heavier. I added about 5lbs each corner and the car felt slower acceleration for the first few days, after that I didn't notice. The improved grip alone out weighed the acceleration loss.
Old 02-08-2015, 02:44 AM   #8
aznatama
aznatama's Avatar
Why would the tires be heavier? No mention of change in wheel size, only weight.
'14 BRZ LTD MT DGM
Old 02-08-2015, 03:56 AM   #9
swarb
I assumed the op was getting new tires also. My mistake. Not worth spending money on couple pounds savings on wheel weight while that money would be better spent on tires.
Old 02-08-2015, 10:21 AM   #10
aznatama
aznatama's Avatar
Even if new tires, they should be about the same weight. With everything else being the same, a lighter wheel will be more noticeable than over 2-3x the weight savings on sprung
weight. Tire weight is not a factor since you would be using the same tire for both wheels.
If you could feel a change from 20 to 17.2, you will feel 17.2 to 14.5.
I'm assuming op is going from a cast wheel to a forged wheel of the same diameter. Otherwise, if going down in diameter, there are a lot of other factors to consider.
'14 BRZ LTD MT DGM
Old 02-08-2015, 08:51 PM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I 100% noticed a difference when I would put my ccw's on, but then again they were 16's. My friend who owns a Genesis also says he can noticed a difference when he puts on his rpf1's compared to his stocks.
Sent from my XT1060 using Tapatalk
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
CSG Mike (02-08-2015)
Old 02-08-2015, 09:21 PM   #12
mrk1
Drives: Sterling BRZ Ltd
Did you notice the change from 20 lb rims to the 17? Its the same weight drop from 17 to 14.
When I had my 100hp mini I hated putting the stockers back on, felt like I had a sack of rocks in the trunk.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-09-2015, 04:31 PM   #13
tennisfreak
Drives: 2018 BMW M240i
Maybe.
I sure as hell noticed taking the spare tire and jack kit out of mine.
Rear end slides around even easier than before!
Old 02-09-2015, 04:39 PM   #14
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
1. Drive around car as is
2. Switch to lighter wheels
3. Remove spare tire and tools from trunk
4. Run single exit exhaust
5. Notice the difference from nearly 100lbs dropped off the car's overall weight
^That's what I did. I definitely noticed.
TylerLieberman is offline   Reply With Quote
Did anyone notice? FRSNewb Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2014 02:59 PM
Wheel weight, will I notice it? Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-09-2014 02:29 AM
Does anyone else notice the similarities? Wes B. Other Vehicles & General Automotive Discussions 3 05-19-2013 08:40 AM
Anyone notice a delay with their car remote? IloveBaldEagles Issues | Warranty | Recalls / TSB 5 11-26-2012 07:10 PM
Anyone else notice... Linseal Scion FR-S / Toyota 86 GT86 General Forum 5 06-03-2012 11:18 PM
