Old 02-06-2015, 10:27 AM   #1
*Hachiroku86*
BAZINGA!
*Hachiroku86*'s Avatar
Drives: 15 FR-S
DIY: License Plate Rattle? Fix Inside!
I'm OCD. Welcome to my life.
This DIY will show you how you can resolve the rattle from your rear license plate if you are not using a license plate frame.
Story:
When I received my license plates, I realized there was a major problem with the trunk mounted one. It wasn't sitting flush. I'm assuming this was because I wasn't rocking a license plate frame. I had to come up with a solution. It rattled and was driving me crazy!!
Solution:
I went to my local autoparts store, and couldn't find anything. So, I made a trip to my local hardware store.
They had what I was looking for! PLASTIC O-RINGS!
Screw these bad boys on, and voila... No more rattle!
Total Time:
5 minutes
Colin Chapman - "Adding power makes you faster on the straights, subtracting weight makes you faster everywhere."
*Hachiroku86* is offline   Reply With Quote
Old 02-06-2015, 10:31 AM   #2
*Hachiroku86*
BAZINGA!
Drives: 15 FR-S
Two more pictures.
Old 02-06-2015, 11:04 AM   #3
ARTBRZ
Aloha!
ARTBRZ's Avatar
I think at higher speeds the turbulence from behind the car will make your license plate flop around. I have the weathertech license plate cover. In addition to that I took a foam or rubber that has a double sided tape (not very thick) stuck 4 behind the license plate so it doesn't scratch the paint. There is no gap between the license plate and my trunk. Never heard any kind of noise from my trunk area.
ARTBRZ is offline   Reply With Quote
Old 02-06-2015, 11:25 AM   #4
*Hachiroku86*
BAZINGA!
Drives: 15 FR-S
I do see your thought process, but the license plate is actually very sturdy. The washers cause a very tight fit which doesn't allow any "play".
I thought of it, but didn't like the fact of putting two-sided tape on my brand new car.
Old 02-06-2015, 12:03 PM   #5
ARTBRZ
Aloha!
ARTBRZ's Avatar
I see your point about the license plate. When I lived in TX the license plate was thicker. The license plate from AZ and here in IN are thinner.
I was just concerned with the curve of your license plate at the bottom. The air tends to circulate up at the back of the car from the turbulence. That can cause it to flop around.
I wouldn't use double sided tape on my car either. It gets messy trying to take it off. I used these rubbarized foam with an adhesive on the back of it. I found these to be helpful for a couple of reason. 1st there's no protection from the aluminum plate to the trunk which = scratch if it moves around. 2nd if you have a subwoofer the rubbarized foam will dampen the vibration from the trunk which = no vibration.
Old 02-06-2015, 12:24 PM   #6
Gunman
Drives: 2019 Mazda Miata RF
I put foam weather stripping on the back of the tag.
Gunman is offline   Reply With Quote
Old 03-09-2015, 03:51 PM   #7
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Any gains in HP or or Torque from this mod?
MightyMeeple is offline   Reply With Quote
Old 03-09-2015, 04:21 PM   #8
ARTBRZ
Aloha!
ARTBRZ's Avatar
Two whp per foam application.
Old 03-09-2015, 04:47 PM   #9
Koa
I outlined my license plate with Damplifier Pro
Currently have a JL 12W6V2 pounding away and no rattles- from the plate
Just put some CLD on the back of it and call it a day...
*GROUP BUY* Rho-Plate License Plate Mounting Kit $40! Massdrop Groupbuys 45 10-15-2013 07:07 PM
License plate covering front plate effect cooling? Wolfkiller Scion FR-S / Toyota 86 GT86 General Forum 4 05-04-2013 07:19 PM
Look up license plate? DarrenDriven Northwest 7 03-17-2013 02:24 PM
Licence Plate Rattle itdansharpe Electronics | Audio | NAV | Infotainment 4 03-13-2013 10:31 AM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
