Old 02-04-2015, 05:38 PM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
light rattling randomly on acceleration?
Not shifter rattle and doesnt sound to ne coming from engine but maybe something up front...anyond had this issue and if so what did you do to fix it? Sounds likr somethings loose and vibrating around 3k. Only mods are intake exhaust openflash tablet and coilovers.. someone told me it was the stoxk header heat sheild? Also only happens under load
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 02-04-2015, 06:06 PM   #2
I would check the heat shield.
Pretty vague description to try to guess anything else.
Old 02-04-2015, 06:08 PM   #3
swarb
ya, heat shield or check exhaust gaskets.
Old 02-04-2015, 10:25 PM   #4
BRZnut
Drives: BRZ DGM Limited
can you post a video of the sound? Another rod knock?
Old 02-04-2015, 11:16 PM   #5
Estey
Drives: Scion FR-S, Ultramarine
same thing just started with me. It might be a different issue though. It sounds like a loose connection, or some type of leak next to the front pipe. My exhaust is much louder than normal and something rattles when I start the car up. Sometimes it stops, and the exhaust sounds normal once the car warms up, and sometimes it doesnt. I just need to get under the car to find out for sure.
Estey is offline   Reply With Quote
Old 02-04-2015, 11:25 PM   #6
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
I have always had the exact same thing. Only sometimes, if I lean into the throttle there's a tiny quick rattle, if I let off and tap sharply it might happen one more time but after that if I try to replicate it it won't happen until later. Rarely happens, usually when I'm in a higher gear but that is maybe the only reason I hear it over the exhaust.
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
Old 02-06-2015, 07:36 AM   #7
nickmerronesucks
Ned flanders
Yes this!! Been trying to record it for two days now and it wont happen. Def not a rodknock or exhaust leak. just annoying
797Performance.com
Old 02-06-2015, 08:33 AM   #8
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Try flashing it back to stock and see if the noise goes away. Could be the timing advance causing a harmonic noise in the exhaust around that RPM.
2016 Camaro SS is offline   Reply With Quote
Old 02-06-2015, 09:36 AM   #9
nickmerronesucks
Ned flanders
Was going to try that because i was reading another thread where that was the noise! thanks guys ill report back
797Performance.com
Old 02-06-2015, 09:37 AM   #10
2016 Camaro SS
Drives: Fast
Reason I mention this is because when I flash back to stock for inspection, my car is about 10 times quieter around that rpm. The tune really increases the volume.
Old 02-06-2015, 11:15 AM   #11
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The openflash tune's have cam timing in that region which makes a pretty loud metallic rasp like sound. It's not harmful, it's just a sound. But yes flash a stock map and make sure it's not something other than that.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 02-06-2015, 11:42 AM   #12
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Does it sound anything like this?
I'm on oft stage 1 stock and I'm getting this rattle as well that is most definitely separate from the rasp around 4k you get from the tune
https://copy.com/qBQ0lSeoas9OFGSu
https://copy.com/JqSNPV1iHHENEg9Y
Kronos is offline   Reply With Quote
Old 02-06-2015, 06:59 PM   #13
fatalelement
I'm untuned and I get this noise, so it's probably not entirely the tune
Old 02-07-2015, 03:13 PM   #14
ali
Yes! I've been hearing this for a while, I'm on a stock '15 BRZ. I am able to recreate this sound continuously by jerking the car using acceleration, around 3k on the 4th/5th gears, accelerate then lift off, and repeat.
I'm subscribing to this thread because the sound is concerning to me, thank you for bringing this up!
ali is offline   Reply With Quote
Used car from dealership randomly dies, what to do? mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 11 08-20-2014 07:41 PM
AC HVAC turns on randomly DarkestBuddha Electronics | Audio | NAV | Infotainment 0 06-28-2014 08:53 PM
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 12:34 AM
Car Alarm Randomly Triggers nathanR Electronics | Audio | NAV | Infotainment 2 09-03-2013 10:41 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 11:17 AM
