Northwest AK, ID, OR, WA
Old 02-04-2015, 04:36 AM   #1
Kolian
Kolian's Avatar
Drives: Raven Black scion frs
my center cigaret lighter/12volt output is not working?
Hi guys i have been having this electrical issue for the past month and cant seem to find the problem. The 12volt output right in the middle by the cupholders is not working i checked through my fuses they seem to be fine and i dont know what else could be causing the problem. The 12 volt output behid the glovecompartment works fine tho. If you can help in any way i apriciate it.
Kolian is offline   Reply With Quote
Old 02-04-2015, 05:18 AM   #2
swarb
swap fuses. don't simply visually check them.
Old 02-04-2015, 01:31 PM   #3
Kolian
Kolian's Avatar
Which fuses? If you could narrow it down. Because i know one fuse controlls both of the 12volt outputs. And one works and the other doesnt.
Old 02-04-2015, 02:14 PM   #4
asphaltfrs2014
Drives: Frs
Have you jumped into the electrical going into that outlet for any aftermarket parts such as a lighted center plaque of anything?
asphaltfrs2014 is offline   Reply With Quote
Old 02-04-2015, 02:36 PM   #5
swarb
http://www.ft86club.com/forums/showthread.php?t=35847
did you replace the fuse mentioned here? someone also says subaru 12v sockets come loose often.
Any output on M7 T-Titan or MXP Catback Simon99 Engine, Exhaust, Transmission 10 09-13-2015 04:22 PM
Subwoofer output for Bespoke Premium bebopblues Electronics | Audio | NAV | Infotainment 5 11-29-2014 04:27 AM
Spliting analog output signal (0-5v) to two inputs. marcoaferrer Software Tuning 16 02-27-2014 11:29 AM
pt546-00140 Sub Output dgerny Electronics | Audio | NAV | Infotainment 1 01-09-2014 02:56 AM
Interesting Findings about BRZ Audio Output Chad_W Electronics | Audio | NAV | Infotainment 14 05-03-2013 09:28 PM
