Old 02-03-2015, 09:20 AM   #1
mortybryant
mortybryant's Avatar
Drives: Scion FR-S RS 1.0
Upgrade Wheels RS1.0
Hello everyone. I'm very new to this site and I've been doing research for the past couple of weeks, so please bear with me.
I have a '15 RS1.0 and I'm looking to upgrade wheels/tires. I'm running the stock suspension (TRD lowering springs). I'm looking for a flush flt, maybe a slight poke. I'm trying to figure out what I can get by with without any rub inside or out. I'd like the idea of an 18x9 rim and a meatier tire, but I'm wondering if I can get away with this on stock suspension. I like the Avant Garde M310 18x9 +30 on 245/35R18 tires. What do you guys think?
mortybryant is offline   Reply With Quote
Old 02-03-2015, 09:50 AM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
The sticky above has tons of fitment examples, pictures, and answers to all your questions.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-03-2015, 09:57 AM   #3
mortybryant
Yes, I've found plenty on the wheels and tires, but my main concern is whether or not it will work with the stock RS1.0 suspension. I haven't ran across a thread that addresses this exact topic yet.
Old 02-03-2015, 10:02 AM   #4
aznatama
aznatama's Avatar
from what I know, the suspension is the same, just has TRD springs. Clearances should be the same as any other FRS/BRZ on lowering springs.
'14 BRZ LTD MT DGM
Old 02-03-2015, 10:18 AM   #5
wparsons
wparsons's Avatar
^^ This, the RS suspension isn't any different (other than ride height) from every other stock FRS/BRZ/GT86 out there. Look at examples at a similar ride height (not on coilovers) and you'll be fine.
For a 9" wheel you're going to want around +35 for clearance, but it'll definitely poke a bit without some camber.
flickr
Old 02-03-2015, 11:29 AM   #6
mortybryant
I appreciate all the feedback. What would be a good summer tire? I really like the Nitto Invo, but can't find in a 245/35, plus I'm not hearing too many good things regarding treadwear.
Old 02-03-2015, 02:21 PM   #7
wparsons
wparsons's Avatar
What do you want out of the tire? Max grip? Best life?
flickr
Old 02-03-2015, 02:39 PM   #8
mortybryant
Honestly, I don't know. I'm up in the air. This isn't my DD; I only drive on the weekends and the occasional evening.
With a completely stock motor, I'm also concerned that a 9" wide wheel will noticeably slow the car down. Any comments?
Old 02-03-2015, 03:24 PM   #9
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
it will make the car slower... but it is brand new to you so in no way are you use to it, so switching to 9" and adding weight will not really confuse you.
However if you put the money up and get a super light weight wheel, you will not be hit with any weight penalty and just get added grip
Old 02-03-2015, 03:25 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
the car is slow already...it won't really be noticeable. I had 18x9 on my car when it was stock.
Unless you're being paid to race/win, don't worry about weight...IMO
Everyone on here likes to talk a big talk about weight(A LOT of people on here are "on paper" racers) and blah blah blah, but it makes relatively little difference except for a few fast folk on here.
Have you looked at the hankook v12 evo2? Decent tire, decent treadwear.
Also, the +30 might be a bit much, but you'd have to double check...My wheels were 18x9 +40. But consult the wheel/tire thread for more aggressive fitments.
Old 02-03-2015, 04:09 PM   #11
mortybryant
Will the +40 offset clear the stock suspension? The only reason I've stated a +30 offset is because I was pretty sure it was safe. If I can go with a larger offset, I'd like to. I believe I can get the M310s in a +38. And the +30 will just give me more poke right? There be other differences, but like I stated this is a new area for me.
Old 02-03-2015, 04:16 PM   #12
continuecrushing
the +40, for my wheel anyway, cleared stock suspension/fenders-barely. There was very little room between the wheel and the strut/spring. The +38 will sit inside the fender more, while the +30 will poke more. How much? Don't know...IMO, I would do +38 before +30, though. But check the fitment/size guide to see what other people have done before making a decision.
Old 02-03-2015, 05:11 PM   #13
mortybryant
Do you have a picture of the +40 setup?
Old 02-03-2015, 05:23 PM   #14
continuecrushing
http://www.ft86club.com/forums/showp...1&postcount=29
Need to upgrade the oil pan for the FRS/BRZ? Hanakuso Engine, Exhaust, Transmission 5 12-28-2014 12:54 PM
best 30$ upgrade so far. bacon_cheese_beer Electronics | Audio | NAV | Infotainment 3 07-03-2014 12:14 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
FR-S HID Upgrade? frsinpa Cosmetic Modification (Interior/Exterior/Lighting) 25 06-18-2012 08:43 AM
What will be the first upgrade you buy for your FR-S / BRZ? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 9 02-26-2012 07:30 PM
