Old 02-03-2015, 05:45 AM   #1
ckim
Drives: '15 DGM STi Limited
Help me decide -- Tomei UEL vs. OpenFlash UEL
All input welcome! Thanks!
ckim is offline   Reply With Quote
Old 02-03-2015, 06:23 AM   #2
Thatguyjeremy
Drives: 13' Asphalt FRS
I have the tomei, I am absolutely pleased with it.
Thatguyjeremy is offline   Reply With Quote
Old 02-03-2015, 07:36 AM   #3
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Do you have an Open Flash Tablet? If so, the Stage 2 uel tune was written with a car using the open flash header. Makes sense to buy that one to me.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Sleepless (02-04-2015)
Old 02-03-2015, 10:41 AM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I know which one performs better since one of our earlier OFH prototypes had a merge similar design to the Tomei.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
DustinS (02-03-2015), FRSBRZGT86FAN (12-05-2015)
Old 02-03-2015, 12:30 PM   #5
fguadamuz
Drives: 2013 BRZ Silver M/T
@Shiv@Openflash can you elaborate on the difference of the collectors?
fguadamuz is offline   Reply With Quote
Old 02-03-2015, 12:38 PM   #6
vroom4
Kind of a blanket statement...what does "performs better" mean?
vroom4 is offline   Reply With Quote
Old 02-03-2015, 12:45 PM   #7
lucid215
im running the OFH and i like it
lucid215 is offline   Reply With Quote
Old 02-03-2015, 12:49 PM   #8
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Neither, go JDL UEL.
2016 Camaro SS is offline   Reply With Quote
The Following 5 Users Say Thank You to 2016 Camaro SS For This Useful Post:
Akari (02-03-2015), drewbot (08-09-2015), EpicNameBro (02-03-2015), tahdizzle (02-03-2015), Teseo (02-03-2015)
Old 02-03-2015, 12:58 PM   #9
OkieSnuffBox
Drives: '23 BRZ Limited
Based on?
Old 02-03-2015, 01:41 PM   #10
2016 Camaro SS
Drives: Fast
Originally Posted by OkieSnuffBox View Post
Based on?
Tons of customer dynos. Drift Office also has a nice writeup on it too. Just ask any of the major tuners what they think about the JDL UEL and its all positives. Still one of, if not, the highest performing UEL out there. Lifetime warranty, coating options, and very high quality. Just comes with a price.
Not to mention the header is where the highest gains come from N/A outside of changing over to E85. It's a very important part to have done right when tuning.
Old 02-03-2015, 06:15 PM   #11
steve99
@ckim suggest you read basic bolt on mod guide link below
you will need a tune to get best results from header , budget for a tune and header package
DAEMANO (02-03-2015)
Old 02-03-2015, 06:39 PM   #12
DAEMANO
Time Traveller
@ckim
As both @steve99 and @Takumi788 have mentioned. Either header would be a good choice, but I would choose the OFH if you plan on tuning with an OpenFlashTablet. You'll need a tune to get the most from your new header. Also you'll earn OF Dollars to lower the price of your OFH.
Almost everything over $500 I've seen on this board are well made and tracked on dozens of cars just on this board. As far as the "high end" goes, keep in mind most catless headers produce the similar power numbers, so don't over spend just to hit a certain brand. The two you've mentioned are solid. Alternatively don't under spend (which it doesn't look like you intend to) because you could end up with quality (not power) issues.
Old 02-03-2015, 07:06 PM   #13
ckim
Thanks All.
Just to fill you guys in -- I have the OFT and plan to run the Stage 2 UEL 91 octane tune. If I stop being lazy I'll try out the e85 tune.
Tomei UEL might be more convenient since I can buy and have it installed in one shot locally, but I'm currently leaning towards the OFH and installing it myself. I've been doing the modding thing since 2000 (had a JRSC'ed Integra GS-R), but I've gotten older and lazier in the 15 years since and am tempted to just let someone else do the work for me.
Old 02-03-2015, 09:00 PM   #14
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
actually DO recommends the tomei as it yielded the best mid range torque and almost matched the HKS EL header in peak HP and at around the 650 mark is really good bang for your buck.
if i recall his numbers he got 192HP with the Tomei, 188 with the JDL UEL and 182 with the borla UEL and for reference, 195 with the HKS. all numbers are on pump gas (92)
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
OpenFlash Tablet will not connect to OpenFlash Manager rever5e Software Tuning 10 03-12-2022 10:17 AM
Openflash Tablet + Openflash Header smellslikecurry Engine, Exhaust, Bolt-Ons 9 12-01-2014 06:20 PM
JDL UEL + OpenFlash Tablet Stage 2 + Tomei Type 80 andrew5826 Engine, Exhaust, Transmission 37 06-16-2014 05:53 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
Tomei Exhaust with Tomei Straight Pipe leech Engine, Exhaust, Transmission 10 01-07-2014 10:42 AM
