Old 02-02-2015, 03:22 PM   #1
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
Kartboy Short Shifter Kit
Anyone have any issues with the kartboy short shifter being kind of clunky? Hard to shift at sometimes? Also, downshifting into 2nd seems to be a chore. It just doesn't seem to be as smooth or fluid as the stock shifter. I know I know, if I loved the other shifter so much, put it back in, but I just didn't know if it was an install issue, fitment issue, or possible defect.
Thanks.
FloridaBRZ is offline   Reply With Quote
Old 02-02-2015, 03:25 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
its a shorter throw shifter compared to stock, so shifting will require more effort.
Have you adjusted the reverse lockout plate?
More importantly, have you changed the transmission oil?
Old 02-04-2015, 07:46 PM   #3
Funk
No-Club
Drives: Subaru Brz
i just installed my short shifter yesterday , so far i love it . but you probably didnt adjust your plate right and if your hearing a noise you didnt tighten something down it happened to me after i drove it but i took it back apart and fixed it
Funk is offline   Reply With Quote
Old 02-04-2015, 08:47 PM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
FWIW, Kartboy shifter lowers the linkage point which causes an indirect transfer of force to the transmission side, thus making it harder to shift. A raised pivot point solves this, but adds substantially to the cost of a shifter. Examples of these are the STi shifter, and the TWM.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
KartBoy Short Shifter DIY and Review F1point4 DIY (Do-It-Yourself) Guides 274 06-02-2017 05:48 PM
FS: Kartboy Short Shifter lickitysplit Interior Parts (Incl. Lighting) 2 11-11-2014 07:27 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Kartboy Short Shifter phatpanda Transmission and Driveline 8 03-22-2014 12:45 PM
Kartboy short shifter problems... cjsporl1996 Engine, Exhaust, Transmission 23 02-24-2014 12:57 PM
