Old 02-01-2015, 08:05 PM   #1
Itzed
Drives: 2014 BRZ Limited
When 5.8 really equals 6.25
Did my first oil change on the BRZ today at 5,909 miles. Will probably change again at 10,000 miles, and settle into 5000 mile intervals afterwards. By the time I checked my oil level for the first time on the car, it was just slightly below the second hole (full mark) on the dipstick. I figured it might be burning a little, since it's new, but it never changed after that. So I put in about 5.8 quarts today, and what do you know, it's right below the second hole again. I added what was necessary to get it right to the full mark and it turned out to be about 6.25 quarts. I assume they probably measure out 5.8 quarts at the factory during initial fill. So I wonder if it really needs 6.25, or if I just got a short dipstick (setting myself up with that one). My garage is level, and the dipstick was all the way pushed in. What have others found?
Itzed is offline   Reply With Quote
Old 02-01-2015, 08:51 PM   #2
Akari
Drives: 2013 DGM BRZ
What is your procedure for filling and checking? I've found it takes a good heating up and 30+ minute wait period before all my oil is back down in the pan.
Akari is offline   Reply With Quote
Old 02-01-2015, 09:02 PM   #3
Itzed
I've checked it cold in the morning, and warm after a drive. The oil expands a little when hot, but not much in this car. My previous 2.5 boxer was worse, or maybe the oil was more susceptible to expansion. FWIW, I had two BMW 3 series cars simoutaniously at one point, both with the 2.5 six, both calling for the same amount of oil, and one consistently took almost a full quart more to get to the full mark on the dipstick. Maybe my local Walmart siphons oil out of some of the 5 gallon jugs before I buy it. ��
Old 02-01-2015, 09:25 PM   #4
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Mine seems to use about 5.3 quarts at oil change time. See this thread that I started:
http://www.ft86club.com/forums/showthread.php?t=11734
A gallon is 4 quarts, are you sure you didn't put in a gallon + 1.25 quarts = 5.25 quarts?
Old 02-02-2015, 04:53 AM   #5
Itzed
Nope, five quart jug, then a little more than another quart.
cold weather equals non operational windows Shit Luck Issues | Warranty | Recalls / TSB 45 11-01-2016 11:32 PM
Power equals Speed poptopclk Forced Induction 25 09-15-2014 12:14 PM
