Old 02-01-2015, 07:42 PM   #1
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I'm looking to upgrade speakers
I don't wanna spend big bucks on new speakers but something better than stock. Any suggestions on brands? Or would it be ideal to just upgrade the amplifier for better sound quality? Add self powered sub for better bass? Any suggestions/advice will be greatly appreciated.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-01-2015, 07:45 PM   #2
kuidaore
What exactly is "big bucks"? What is you absolute budget? You'll end up having to get an amp for sure if you want to run sub+speakers.
kuidaore is offline   Reply With Quote
Old 02-01-2015, 08:07 PM   #3
86geek
86geek's Avatar
$300.00 is my budget....I don't wanna spend more than that....just want a better sound than the stock....
Old 02-01-2015, 08:43 PM   #4
nivek111070
Drives: 2014 GB Scoobie BRZ
You won't get better sound from just speakers in fact just the opposit.
I put in my focals before adding the amps and it was not better until the amps were installed
nivek111070 is offline   Reply With Quote
Old 02-01-2015, 08:48 PM   #5
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
[ame="http://www.amazon.com/gp/product/B002BZFSYA/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1"]Amazon.com : Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance 2-Way Speakers (Pair) : Vehicle Speakers : Car Electronics[/ame]
Infinity Reference
Brought a pair of these to replace the stock door speakers much clearer sound and its actually two speakers so now its a 10 speaker system in my car.
brandonblt2 is offline   Reply With Quote
Old 02-01-2015, 08:53 PM   #6
brandonblt2
Not true your focals were probably 4 ohms if you pickup 2 ohm speakers you wont need to upgrade the stock amp and you will still get a better sound.
Old 02-01-2015, 09:52 PM   #7
86geek
86geek's Avatar
Infinity Reference
Thanks...so I wouldn't need to upgrade the stock amp with those speakers?
Any other suggestions on speakers/amp for a budget of $300.00? Thanks
Old 02-01-2015, 10:36 PM   #8
brandonblt2
Yup with this speakers you don't need to. For me it sounds good pretty good right now but I have a upgraded headunit I would suggest adding some more sound deadening to the doors to reduce some the road noise.
Old 02-03-2015, 01:42 AM   #9
Antairez
Drives: Mazda 3
Has anyone on the forum tried the oem audio plus? Curious how the speakers were improved because I don't really care about the sub....
Antairez is offline   Reply With Quote
Old 02-03-2015, 02:24 AM   #10
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
I wonder how much the HU had an effect to the speakers you got... When I had an aftermarket HU on a different car, the stock speakers were pushing out more and sounded better.
tigermack is offline   Reply With Quote
Old 02-03-2015, 03:06 AM   #11
meWant
Drives: '16 BRZ Limited
Do you know if these can be used [ame="http://www.amazon.com/Infinity-629I-Two-Way-Speakers--Inch/dp/B0019G2HA0/ref=sr_1_7?s=car&ie=UTF8&qid=1422949726&sr=1-7#productDetails"]Infinity 62.9i Two Way Speakers[/ame] in a plug and play manner for the door speakers?
if they can, can anybody also tell me what else I will need to install them. This would be my first speaker install so if I can get by with running the factory wiring for now that would be great and also if I need a spacer, are there any recommended ones that would be compatible with these?
meWant is offline   Reply With Quote
Old 02-03-2015, 08:09 AM   #12
brandonblt2
Originally Posted by meWant View Post
Do you know if these can be used Infinity 62.9i Two Way Speakers in a plug and play manner for the door speakers?
yea looking at them they should be since they're 2ohm speakers. I used metra 72-8104 for wire connectors easy plug and play. The spacer I used was Scosche 6.5" spacer but this one required modifications to use so I would recommend going up a size.
[ame="http://www.amazon.com/gp/product/B000NWCIEG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1#produc tDetails"]Amazon.com : Scosche SAT6 Speaker Adapter for 2000-Up Toyota Echo/Avalon : Vehicle Speaker Installation : Car Electronics[/ame]
[ame="http://www.amazon.com/gp/product/B0002BBP7Y/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1"]Amazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: Electronics[/ame]
Old 02-03-2015, 08:16 AM   #13
brandonblt2
Well my headunit is more of android device where they focused more on the display, feel, and app integration versus the sound quality you would get from a Kenwood or JVC. So sound improved slightly over stock enough to notice tho.
Old 02-03-2015, 09:06 AM   #14
Chimera
Drives: FRS
This guy for spacers http://www.subaruaudio.net/
Door speakers upgrade / replacement mike_ekim1024 DIY (Do-It-Yourself) Guides 13 02-17-2015 07:29 PM
New speakers all around! EightSix93 Cosmetic Modification (Interior/Exterior/Lighting) 14 01-28-2015 12:20 AM
Door speakers don't work after HU upgrade BigJyoungblood Electronics | Audio | NAV | Infotainment 18 05-30-2013 11:46 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
Thoughts on the BRZ radio/gps/speakers - Should we upgrade? dorkymork Electronics | Audio | NAV | Infotainment 21 01-30-2013 11:04 AM
