Old 02-01-2015, 03:37 PM   #1
trsiidno
Drives: .
Longer Gears
My car is FI but I feel like the gears arent long enough. What option are there for me since I hit 148 pretty often and it starts slowing down drastically there. I will be doing e85 so power isnt gonna be a problem. And if right now I just have 330 hp how much will it affect the speed of the car for the time being not e85.
trsiidno is offline   Reply With Quote
Old 02-01-2015, 04:04 PM   #2
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Grab yourself an M85 differential out of a 02-05 IS300.
3.73 FD as opposed to the stock FT86 being 4.10.
EDIT: Not terribly hard to find, but they aren't plentiful. I bought mine for $575 shipped. It is a *direct* swap. You need to pull the IS300 axle shafts out, and the rest is straight bolt in.
slicktop is offline   Reply With Quote
Old 02-01-2015, 04:30 PM   #3
kodyo
Drives: Scion FR-S
Agree with what slicktop is saying. Pulled my diff out of an IS300, but it was only $250 for mine. If you live in a big city (Houston for me), there are quite a few for sale if you call around.
M98 diff will work as well, but will have a 3.9 FD in it instead of the 3.73 tha the M85 has.
kodyo is offline   Reply With Quote
Old 02-02-2015, 01:57 AM   #4
Mike Brz
What is the stock gear ratio?
Mike Brz is offline   Reply With Quote
Old 02-02-2015, 03:25 AM   #5
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Read post #2
Digitalanalog is offline   Reply With Quote
Old 02-02-2015, 03:56 AM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Dipstik-sportech
Old 02-02-2015, 06:22 PM   #7
Dipstik-sportech
Dipstik-sportech's Avatar
You rang!!! I've done the 3.73 diff swap. For forced induction it's almost a must do. Makes highway pulls a much less frantic experience lol, less shifting and more speed per gear.
Old 02-03-2015, 07:52 PM   #8
trsiidno
Drives: .
So to do this install is there a diy what exactly do i need to buy to get this fully swapped.
Old 02-03-2015, 07:56 PM   #9
Dipstik-sportech
Its 4 bolts and two axles, you want an is300 diff tagged m85
Old 02-03-2015, 08:02 PM   #10
trsiidno
Drives: .
Thats all i need? Is just the differential? Whats the normal price for one too
Old 02-03-2015, 08:07 PM   #11
Dipstik-sportech
I paid $600 for mine. It's a whole differential unit so u just pop the axles, remove the driveshaft and take the 4 mount bolts out and replace it with the is300 one.
Old 02-03-2015, 08:14 PM   #12
trsiidno
Drives: .
I dont get how any of this works but i have a guy that sells the diff for that car do i just say i need the m85 differntial and thats it?
Old 02-03-2015, 08:14 PM   #13
trsiidno
Drives: .
Just checking read the post above
Old 02-03-2015, 08:49 PM   #14
slicktop
It's literally bolt in. The transfer case/pumpkin is the exact same unit with different gearing inside.
Google "frs differential" and google "m85 differential". They're the same *exact* transfer case. On the M85, you will see the axle stubs where the axles go in. Those litereally pull out and you install it.
I had questions and @Dipstik-sportech helped me out because I couldn't believe it was literally drop in. It was. I don't know how else to put it.
EDIT: Look at my build thread, I have some pics there.
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 01:55 PM
Smoothing out 1st and 2nd gears BRZerk Engine, Exhaust, Transmission 33 02-26-2013 05:30 PM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
Changing Gears Naughty AFRICA 10 01-09-2013 12:30 PM
