Old 01-26-2015, 11:03 PM   #1
Str8Ghostin
Drives: 2014 Raven Scion FRS 6MT
For the time attack guys, Traction Control on or off?
I know I know it's supposed to be completely off when we're racing (and during open days that's exactly what I do because it's fun to slide around), but when I compete in Time Attack I'm finding that I get better times with the traction control on and VSC engaged.
With it on, my turn in speed on big corners is much better
With it off, my time through the multiple low speed corner sections is much better
Overall, I get better times (on each track I've been on) when I leave it on but is that just inexperience on my part? I've only been tracking for 3 years now and up until this past season it was in a FWD Integra. Am I limiting myself by leaving it on? I'm on Ventus V12 EVO's fyi.
Str8Ghostin is offline   Reply With Quote
Old 01-26-2015, 11:07 PM   #2
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I think most guys do the pedal dance, turning off ABS and all traction control.
Bobblehead is offline   Reply With Quote
Old 01-26-2015, 11:16 PM   #3
swarb
You should be faster with it off, as there is no intervention/braking being done to slow down wheels. Chances are, at those big turns where you are faster with it on,, your brain is telling you it's "off" so you take it a little bit slower because you are scared.
How do you know you are faster or slower? logs?
Old 01-26-2015, 11:20 PM   #4
Str8Ghostin
When I compete all of the time info is taken from the mounted transponder.
And honestly I think you might be right, I distinctly remember that going through my head mid corner lol. Any tips as to how to work around this?
Old 01-27-2015, 03:39 AM   #5
It means you need more seat time.
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
CatDaddysBBQ (01-30-2015), ImperiousRex (01-27-2015), powerj2 (02-11-2015), Silver Ignition (03-13-2015), tigermack (01-30-2015), Toyota GT 86 (02-15-2015), wparsons (01-27-2015)
Old 01-27-2015, 07:31 AM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
TC actually cuts ur power. So ya .....
<-keyboard warrior
Old 01-27-2015, 08:55 AM   #7
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Nothing about VSC will make the car mechanically faster around a corner. You are simply more comfortable knowing that it's on and willing to dive deeper at the entrance. It's simply mental. Your tires have a limited grip threshold but they are progressive and predictable when you begin to exceed their limit. Early on I committed a couple sessions to exploring VSC and quickly realized that it is nothing like some of the PTM systems now available in higher end cars and in fact many factory race cars. It is extremely intrusive and unpredictable when driving the car beyond what the system is designed for.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
zdr93523 (02-05-2015)
Old 01-27-2015, 09:18 AM   #8
DarkSunrise
DarkSunrise's Avatar
I was curious about TC last year (normally track with it off) and so I left it on a few sessions. One of faster guys in my group told me he noticed I had slowed down in corners, so it's definitely a noticeable change in speed. You can feel when it intervenes.
Personally I never thought it destabilized the car or anything like that, but everything felt artificial. I was just flooring the throttle mid-corner and there was no rotation at all (and barely any acceleration). Very strange feeling. I turned it off again and never looked back.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
CSG Mike (01-27-2015)
Old 01-27-2015, 10:02 AM   #9
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Pedal dance does not turn off ABS AFAIK.
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
killboy (02-05-2015)
Old 01-27-2015, 11:07 AM   #10
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Honestly if the stability control isn't bothering your intended driving then keep it on. As you progress it will eventually become obvious it's interfering with how much slip angle you're trying to achieve.
Traction control is something on an NA car that may only be useful in the rain. On a high power FRS, traction control is more useful. Now on our car we use the Hydra EMS to tune the traction control for each gear independently as I have found this to be critical when trying to go faster with TC. Now on our car and the Hydra EMS we can turn all stability control off but still run programable traction control but I don't believe you can on the factory ecu.
Element Tuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
CSG Mike (01-27-2015), ImperiousRex (01-27-2015)
Old 01-27-2015, 11:58 AM   #11
wparsons
wparsons's Avatar
If you're driving right, there's no way it's faster with TC/VSC on. If you're running faster laps with it on, you're making mistakes that the ECU is protecting you on.
flickr
Old 01-27-2015, 02:02 PM   #12
renfield90
The Stig's German cousin
+1. The OEM TC/VSC is super intrusive on any setting besides "off."
I keep pounding this drum around here: learn to drive your car without your electronics. Make mistakes and learn from them.
This is not a GTR, the electronics WILL impede your performance.
Old 01-27-2015, 02:15 PM   #13
Str8Ghostin
Thanks for all of the advice guys, I'll be sure to keep it off in this upcoming season and progress that way. I have a feeling it's the mental/fear/no fear aspect that I need to get over (and obviously improve on some techniques as well).
Just to clarify I have driven with it off at the track multiple times (open days) its just when I was doing time attack I was pulling slightly faster time overall so I'd leave it on for that when the laps counted.
Old 01-27-2015, 02:28 PM   #14
Use the pedal dance; the 5 second hold does not fully remove the nannies and electronics.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
First time traction control off experience Nate219BRZ BRZ First-Gen (2012+) — General Topics 6 08-13-2012 04:35 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
