Old 01-22-2015, 06:35 PM   #1
vroom4
Solved
Solved
vroom4 is offline   Reply With Quote
Old 01-22-2015, 06:36 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
if you're gonna tap it, you better wrap it!
-Jack Burton
Old 01-23-2015, 11:04 AM   #3
Wepeel
Drives: '13 BRZ Ltd
Nothing documented, but I have Torque up and running all the time in my car. Since I installed unwrapped/catless headers, I've noticed no difference in oil temps or iat's. I have noticed it seems the "Cat1BS1" variable, which is some form of exhaust temperature, has lowered quite a bit with the unwrapped/catless headers. I seem to remember the stock header exhaust temps generally being in the 1000-1200 range regularly, with the new header it is more like in the 900-1100 range. Of course, there's no cat, so that might make perfect sense - I'm not really sure what the variable actually is.
Wepeel is offline   Reply With Quote
Old 01-23-2015, 11:33 AM   #4
mike the snake
I think it would make sense that the EGT's would be higher with wrapped or coated exhaust because they help keep the heat IN, and keep the heat from radiating out, into the engine bay or wherever.
Also without cats, there's probably less backpressure, so less time for the exhaust to heat things up.
Old 01-25-2015, 03:55 AM   #5
350matt
Drives: toyota mr2/ Toyota GT86
having no cat makes the biggest difference to exhaust temps
as a cat will increase back pressure so it slows the exhaust flow and therefore increases the EGT
plus the cataylst once its up and reacting will generate its own heat
350matt is offline   Reply With Quote
Old 01-26-2015, 12:40 PM   #6
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by vroom4 View Post
Notice anything around the headers getting extra warm?
No, not really, although I've never really checked. I would think any issues would be more during idle than when moving.
I've read a thing or two about failed coil packs, and maybe extra heat had something to do with it (it certainly wouldn't help).
Old 01-26-2015, 01:28 PM   #7
vroom4
Due to lack of any real data, I broke down and am just shipping them to Swaintech today.
Thanks for the responses.
Old 01-26-2015, 01:52 PM   #8
mad_sb
Drives: 2013 Asphalt FR-S
Anyone have any oil temp data from DD or track who has uncoated / unwrapped header? Any data or real experience with how hot the nearby electronics are getting after a normal drive?
Sorry to bring this up, the world of google and ft86 searching did not yield much quantitative information other than "Wrap it","no dont, it will catch fire".
Hot enough to melt plastic connectors on cam sensors and cooling fans if you have one of the long tubes that turns up into the engine bay.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
Interesting intercooler test: Uncoated vs black By MCM SmsAlSuwaidi Forced Induction 20 07-13-2014 08:21 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
