Old 01-20-2015, 03:26 AM   #1
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
Turn signal issues?
So iv had my car for 3 years and still cant get enough... but recently iv stumbled upon an issue. When signaling to turn left the blinker stops making noise and the arrow stays glowing, this had occurred more than once but when I turned the car off the arrow would also turn off. Yesterday I was driving and the issue occurred again, I thought to myself that there would be time to get it looked at later. Once parked I turned the car off and pulled the key out of the ignition and the light stayed on. Looking at the back of the car the rear blinker light was on but not flashing, along with the blinker in the front. So I then get back into my car drove to the dealership with the blinker still locked in, and 4 hours later they give it back saying it was a computer issue. I took it back anxiously and start my drive home. I continuously try to test if the blinker is 100 % functional and as I get toward my exit the issue comes back and the blinker stays illuminated. I take the car back to the dealer and they give me a rental.... Prius . So if you guys have any thoughts on the subject I would really appreciate any info.
Here is what you need to know
1. I have replaced the tail lights with toms and switched the relays
2. The headlights have been replaced by HIDs
3. All this has been done for over 1 year
4. I have done no splicing or electrical work at all
5. The service guy said that they re flashed the ECU to get rid of the problem
6. Flashing the ECU does not fix the problem
7. I have a new found love for the prius
8. I MISS MY CAR
mod on
ric342 is offline   Reply With Quote
The Following User Says Thank You to ric342 For This Useful Post:
Jrryjms07 (01-20-2015)
Old 01-20-2015, 09:11 AM   #2
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
You lost me at #7.
ImBatman is offline   Reply With Quote
The Following User Says Thank You to ImBatman For This Useful Post:
Old 01-20-2015, 09:49 AM   #3
Throw the stock tails back on and see if the problem goes away.
Old 01-20-2015, 09:50 AM   #4
1Cor10:23
1Cor10:23's Avatar
Might be your flash module under your steering wheel?
Old 01-20-2015, 10:15 AM   #5
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
The ECU doesn't control the blinkers, the turn signal flasher module does.
That's a bigger problem than the blinkers not working.
Scenic Driver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scenic Driver For This Useful Post:
ric342 (01-20-2015), Tcoat (01-20-2015)
Old 01-20-2015, 10:33 AM   #6
MrJesse
MrJesse's Avatar
Drives: SWP BRZ
Its definitely the relay. I had the same thing happen to my JDM toms and I had to switch back to the stock relay. I had hyperflashing but its better than a dead battery.
MrJesse is offline   Reply With Quote
Old 01-20-2015, 11:39 AM   #7
ric342
FR-S driver
ric342's Avatar
That is the first thing I did before taking it back to the dealer
mod on
Tcoat (01-20-2015)
Old 01-20-2015, 11:41 AM   #8
ric342
FR-S driver
ric342's Avatar
I have an extra relay, if changed you believe that the problem will be fixed? why the relay though?
mod on
Old 01-20-2015, 11:44 AM   #9
ric342
FR-S driver
ric342's Avatar
Originally Posted by ImBatman View Post
You lost me at #7.
lol the prius gets amazing gas mileage, the dealership is about 12 miles from my house and when i got home it said the trip cost me 63 cents, that is crazy....but that is all it has going for it thus number 7
mod on
Old 01-20-2015, 11:52 AM   #10
ric342
FR-S driver
ric342's Avatar
As I was driving home the thought that it might have been the relay that was changed when the taillights were installed was the cause of all this bugged me, but the first thing that came to mind that day was whether it could be something in the steering column that controlled the indicators. Could that be the case?
mod on
Old 01-20-2015, 12:57 PM   #11
ImBatman
That is pretty impressive. But be wary, driving a Prius almost instantaneously turns you into a holier-than-thou pretentious doucher. Not accusing you or saying it has already happened... just looking out for a fellow 86er. Not a bug you want to catch, my friend!
Old 01-20-2015, 01:19 PM   #12
Wilsonk227
Wilsonk227's Avatar
Drives: Super Vehicular Terrain Vehicle
it's your flash relay module. The reason why it's doing that is because the stock relay is not built for LEDs. I believe tom's supplied the extra relay. That's supposed to work with LEDs but if that still doesn't work you'll have to try something else.
haven't used this myself but people have given this great reviews when it comes to swapping out your tail lights.
http://www3.telus.net/s_mcphee/orderTAP.html
plus you can make it do stuff it normally doesn't
ig: @MrWiils0n
Wilsonk227 is offline   Reply With Quote
Old 01-20-2015, 03:35 PM   #13
ric342
FR-S driver
ric342's Avatar
I got the car back, they did not fix the issue because they said that there was nothing they could do. I got home and connected my other set of toms and they did the same thing so I replaced my LED relay with a new one and it fixed the problem. I have no clue why the first led relay went bad, but im glad that I had an extra.
mod on
The Following 2 Users Say Thank You to ric342 For This Useful Post:
Defuser (01-20-2015), Koa (01-20-2015)
Old 01-20-2015, 04:00 PM   #14
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Thank you for relaying your experience OP.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
switchback turn signal issues dtle82 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-11-2014 07:25 PM
eBay Switchback 7443 LEDs fitment issues in turn signal housing dracullus DIY (Do-It-Yourself) Guides 0 08-27-2014 10:28 PM
Turn signal wiring OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 0 04-06-2014 10:05 AM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 12:47 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
