Old 01-19-2015, 06:03 PM   #1
Green_rino
Drives: 2015 FR-S
Climate control backlight fuse/relay location
Hi everyone,
I have a 2015 FR-S base and was installing a set of Spyder fog lights this weekend and ran into a bit of an issue. I hooked the switch power wire up to the purple wire on the factory fog light plug harness. I was poking around to see which wire turned on the fog light indicator on the dash and I must have shorted the purple wire and blew a fuse. The purple wire is now dead (lost the 12v signal) and I lost the backlight on several things: dash light brightness adjuster, VSC sport and trac buttons, and climate control knobs. Everything works they just don't light up, all other dash lights are on and the white wire on the fog light harness that runs the dash fog light indicator still has 12v. I couldn't find a fuse that was blown in the fuse box. Is there a hidden fuse or relay that I blew and need to replace? The manual doesnt cover these lights/fuse unless it is embeded in another fuse or relay.
Thanks for the help
Green_rino is offline   Reply With Quote
Old 01-19-2015, 06:12 PM   #2
Don't have mine in front of me but all fuse locations are shown in the manual.
Old 01-19-2015, 06:57 PM   #3
Green_rino
Drives: 2015 FR-S
I checked all the fuses in the box and I couldnt find anything for the climate control lights or trac control switch lights.
Old 01-19-2015, 07:03 PM   #4
Well that isn't good!
There are some under the hood but they are more the heavy duty stuff.
Old 01-19-2015, 08:49 PM   #5
Green_rino
Drives: 2015 FR-S
I agree!
Old 01-19-2015, 09:43 PM   #6
Green_rino
Drives: 2015 FR-S
Found the 'second' fuse box. Didn't know it was there, found the fuse all good again.
Old 01-19-2015, 09:46 PM   #7
Good stuff
Old 04-25-2016, 10:58 AM   #8
elr3y100
Drives: 2013 FR-S 10 Series!
I know this is an old post but I recently ran into the same exact problem, where is the "second" fuse box and what fuse did you change?
elr3y100 is offline   Reply With Quote
Old 04-25-2016, 01:24 PM   #9
Open hood. Box is right in front of left hand strut. That big flat black thing.
Old 04-25-2016, 06:46 PM   #10
elr3y100
Yes but I was wondering what fuse he changed to get the lights working again!
Old 04-25-2016, 07:03 PM   #11
He hasn't logged in in over a year so I doubt you will get an answer. The first part of your question was "where is the fuse box?" I answered that part. The second part of your question was "which fuse". That one you are not likely to get an answer on so my best reply is the blown one. Grab your manual and look at the fuse layout and you can rule out the obvious ones to reduce your search.
Old 02-16-2021, 06:35 PM   #12
Nfsundrgrnd
Nfsundrgrnd's Avatar
Drives: 2013 WR blue sport tech BRZ
I'm reviving this thread because I also can't find a blown fuse for the console buttons backlighting... I've pulled 5 fuses that seemed like it could be a fit for the console backlighting but all the fuses were fine... this one man seems to have the answer but he has dissapeared from the forum after fixing his issue lol
Nfsundrgrnd is offline   Reply With Quote
Old 02-16-2021, 10:01 PM   #13
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
There are two fuse boxes. One in the engine bay (the obvious black box), and one that's mounted upside down in the interior, right above the hood release latch.
EndlessAzure is offline   Reply With Quote
Old 02-24-2021, 01:32 PM   #14
Nfsundrgrnd
I've checked both boxes but no fuses were burnt... I'd start pulling random fuses at this point but I don't want to pull something important out lol
Blinker/Hazard Relay Location EmilGH Cosmetic Modification (Interior/Exterior/Lighting) 12 09-10-2015 01:20 PM
Blower motor (fuse/relay/resistor) problem? fx35s Issues | Warranty | Recalls / TSB 6 01-27-2015 09:06 AM
VSC and Traction control fuse location? SunkenFRS Electronics | Audio | NAV | Infotainment 6 11-07-2013 11:59 AM
Tails Fuse Location Ryeong86 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-18-2013 02:49 PM
Fuse Location Shadow215 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:07 PM
