Old 11-07-2013, 10:22 AM   #1
SunkenFRS
Sideways & Smiling
SunkenFRS's Avatar
Drives: 2013 Raven FRS
VSC and Traction control fuse location?
As the title say, I can't find the fuse location for the vcs/trac light. If anyone could help id appreciate it
2013 Raven FR-S
Flossy - Fortune Auto - ESM - Project Kics - Borla - Berk - TRD - HT Auto - Winjet - P3 - Koyo - CarolinaDyno - Mocal - FIC - FBM
SunkenFRS is offline   Reply With Quote
Old 11-07-2013, 11:02 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i didnt know the LEDs had their own fuses...
Old 11-07-2013, 11:04 AM   #3
SunkenFRS
Sideways & Smiling
SunkenFRS's Avatar
Not the LED fuse because that's just the one for the gauge cluster as a whole, the one for the actual system
2013 Raven FR-S
Old 11-07-2013, 11:13 AM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
okay, so your question should be "how do I permenatly disable the VSC and Traction control" (clarity is important)
which you can't actually do by pulling a fuse.. well you can, but then you'll also lose ABS. So if you want to do the dirty, you pull the ABS fuse and everything will shut off.
if you actually want to turn off just the VSC and Traction Control, you hold down the Traction Control button for 5 seconds until both yellow icons light up, you have disabled the VSC and TC but get to keep ABS.
if you want this to be permanent, look up a DIY for a "switch", you'll have to cut into the cabling but it's not that difficult, this will override the need to hold the button down every time by actuating an on/off switch.
bonus mode: "pedal dance"
as all modern cars, even turning VSC and TC they are still actually "on" for the most extreme situations... there is a "secret" technique left from factory that actually disables all electronic nannies (but not ABS) but to do it you have follow a funny sequence of inputs
please follow this thread for more detail.
http://www.ft86club.com/forums/showthread.php?t=25494
Old 11-07-2013, 11:28 AM   #5
SunkenFRS
Sideways & Smiling
SunkenFRS's Avatar
I was trying to turn off the vcs/trac lights from the button and it wouldn't let me. I have a check engine light from my header so when I went sliding yesterday the indicator that says you lost traction was held on in the gauge cluster. I just unplugged the battery and got rid of the CEL which turned the other light off. Now everything's cool. Thanks for all the info though
2013 Raven FR-S
Old 11-07-2013, 11:37 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
erm... i'd have that checked out
Old 11-07-2013, 11:59 AM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
ABS, VSC, and speedo are all linked together tightly. The only way to truly disable them, as far as I know, is to replace the ECU with the Hydra EMS. Perhaps EcuTek or somebody will patch the ROM to allow it.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Fuse Location for Auto Dimming Mirror Harness tonytduc Scion FR-S / Toyota 86 GT86 General Forum 11 11-27-2013 08:46 AM
Tails Fuse Location Ryeong86 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-18-2013 02:49 PM
Fuse Location Shadow215 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:07 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
