#teamswagoi
Drives: 2014 Raven FR-S Monogram
Driver-side door not responding !
Hey there everyone !
I spent some time scroll through the previous threads but could not find an answer . Recently my driver-side door stopped responding as I walk right next to it to unlock my car via handle (keyless lock/unlock) . I find this very peculiar because my passenger-side still responds as I walk up to grab the handle with the fob in range . Did I accidentally pressed something that caused this ? Also my car recently has had some body work done , if I did not press anything I believe this may have caused the issue with the door not responding . It is funny because to others it appears that I am a gentleman who likes to open doors for my passengers when in reality I am too lazy to press the button the fob that is in my pocket . Please help !
If the body work involved the door it is very likely they did not hook the wires back up.
#3 | |
#teamswagoi
Although the door did not get damage in the hit and run accident it is on the same side . I wanted to just figure out what had happened before heading back to my body shop to get it fixed .
Did it work after the accident but before the repairs?
Drives: BRZ Limited
I had the same happen after bodywork. I had the bodyshop check that the wires were hooked up, and they told me that the dealer would need to reprogram it. Only my trunk button still works. I havent bothered to go to the dealer to see though as I know they will charge me, and I forgot about it after I got used to pushing the button on the key. Mine did work after the accident, but before repair.
#6 | |
#teamswagoi
It's funny because I just dropped my car off for service at the dealership ; should of asked them how much it would cost ! I'll see if they will charge for that .
Try holding down the window button for like 10s
Drives: BRZ Limited
Drives: SWP BRZ
#10 |
Drives: MY15 86 GTS
Disconnecting the door handles wouldn't require anything to be re-programed. The sensors in the handles are just that, the smarts are within the central smart entry ECU.
I would bet that there is a harness connector loose or not connected. Probably in the foot well / cowl area. Where was the accident damage? |
#11 | |
#teamswagoi
Planning on dropping by my body shop anyway in the near future to pick up a check , I'll ask them to double check the connection before going to Toyota .
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Driver side door handle | lordtakuban | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 06-19-2014 01:30 AM |
| WTB: Asphalt FRS Driver side Door | qijian | Want-To-Buy Requests | 0 | 11-01-2013 01:17 AM |
| Rattle from driver's side door lock. | Mandy | Issues | Warranty | Recalls / TSB | 0 | 07-10-2013 08:44 PM |
| Shoes Driver side door | gr8scott | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 25 | 05-12-2013 09:22 PM |
