Old 01-18-2015, 09:44 PM   #1
jwvand02
Drives: 2013 SWP BRZ Limited
What should I expect from stock clutch with ~250 rwtq?
Title says it all - anyone spent any significant amount of time at about 250wtq on the stock clutch? Okay as long as I'm not flooring it at 2k in 5th? Will hold for a few thousand but slowly let go? I haven't been able to really find any definitive power levels where the stock clutch lets go, despite a good bit of searching. What seems to be for sure is that this power level will definitely be pushing it if I'm hard on it.
jwvand02 is offline   Reply With Quote
Old 01-19-2015, 09:13 AM   #2
ChrisD
ChrisD's Avatar
Drives: GT86
Not sure if this helps but I was told by Fensport that the standard clutch is only good for up to about 250 bhp, but not sure if that was crank bhp or wheel bhp (and they didn't mention torque, only horsepower). Also in the video about Crawford making their own built motor for the BRZ they said the clutch was one of the first things to go when they started adding more power.
ChrisD is offline   Reply With Quote
Old 01-19-2015, 10:18 AM   #3
protpibe
protpibe's Avatar
I think it's limits are about 230wtq before slipping. Mine started to slip in high gear right around that mark, if memory serves me correctly .
Old 01-19-2015, 10:21 AM   #4
You may want to think about axles as well. Seems that a lot of guys that start putting out much more than 250 start breaking them.
Old 01-19-2015, 10:47 AM   #5
Pete156
I like to eat!
230wtq is about the limit. Driven gingerly (like a redhead) it may last a few months. 4th and 5th gear stomps will quicken the deterioration process considerably. Axles are fine as long as you're not too low.
Pete156 is offline   Reply With Quote
Old 01-19-2015, 12:53 PM   #6
trsiidno
Drives: .
Just to put my two cents in i have 310 whp and i ride that stock clutch harder than hell. The only time it ever slips is if i try to launch other than that its holding up amazingly.
trsiidno is offline   Reply With Quote
Old 01-19-2015, 01:51 PM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
Stock clutch here as well, slips only on 5th and 6th gear under load, otherwise fine. I'm at 250torque iirc
Sent from my A0001 using Tapatalk
mashal is offline   Reply With Quote
Old 01-20-2015, 10:42 AM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Slipping is better then blowing the springs out the disc lol
IG-Joey_Soul
Old 01-20-2015, 12:26 PM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I don't think this is accurate. I've had 380+wtq for more than a year and axles are fine.
I just recently upgrade to DSS axles, but only because of a great deal, not necessity.
The biggest enemy of axles is not wtq, but more living the "low lyfe". Big suspension drops will extend the axle beyond its designed range and they will snap rather easily.
Old 01-20-2015, 12:35 PM   #10
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
this^ i've read plenty of guys at stock power with a big drop snapping their axles.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 01-20-2015, 12:48 PM   #11
Yes! I have read both the higher power (not many, but some) and the big drop (not some, but many) have the issue. What is rare is the stock power, stock height guys having an issue.
Just brought it up because it is a consideration to keep in mind not an "OH my god" moment.
How long do you expect the stock clutch to last? Superhatch Engine, Exhaust, Transmission 29 01-29-2018 03:49 PM
ACT clutch and LWF or stock clutch and Evolution industries LWF Hawk77FT Engine, Exhaust, Transmission 13 12-21-2014 02:14 AM
FS - Stock clutch used 9000km DAN_BRZ Canada Classifieds 3 03-29-2014 11:18 AM
Stock clutch $50 obo PineappleFriedRice Transmission and Driveline 2 11-25-2013 01:21 PM
WANTED! Stock Clutch! JD86 Australia Classifieds 1 07-02-2013 10:21 PM
