Old 01-17-2015, 05:24 PM   #1
jflogerzi
jflogerzi's Avatar
Okay to swap Rotors for tracks days only in fronts?
I am getting tired of my pads squealing like a pig. Thus what I am going to do is run 2 sets of pads. Street pad and a race pad for track days. To keep costs lower, can I only swap the front rotors and use the backs full 24/7.
Second question. Looking for a good street pad with good bite, zero noise and low dusting. I have heard good things about the winmax W2 pads. This will be for street and canyon runs only.
Plan to run Centric Plain rotors for the street and keep my existing stock one for track duty only. I also plan to add steel lines, and a MBC.
Old 01-17-2015, 05:36 PM   #2
jvincent
jvincent's Avatar
You don't need to swap rotors to run different sets of pads.
Old 01-17-2015, 05:43 PM   #3
jflogerzi
jflogerzi's Avatar
I understand this, but I can never get the bedding process right and the noise always come back. But if I swap pads the day before the tracks, whats the best way to bed them during the first session?
Old 01-17-2015, 05:54 PM   #4
jvincent
jvincent's Avatar
Just bed the track pads following the normal procedure if you are changing them the day before.
I have just come to accept that the track will be a noisy day and don't worry about the squealing.
Old 01-17-2015, 06:33 PM   #5
jflogerzi
jflogerzi's Avatar
Its not the track, its the day to day driving I could careless if the sequel at the track.
Old 01-17-2015, 09:00 PM   #6
jvincent
jvincent's Avatar
Sorry, misread your post. Once you switch back to street pads they should not squeal.
One tip, make sure you use brake shims with grease on both sets of pads.
Old 01-17-2015, 09:44 PM   #7
I can help you bed them
Old 01-18-2015, 09:51 AM   #8
wparsons
wparsons's Avatar
If you run pads by the same manufacturer, you shouldn't have to re-bed them after swapping pads.
I believe Carbotech even advertises this for their pads.
flickr
Old 01-18-2015, 12:06 PM   #9
jflogerzi
jflogerzi's Avatar
@CSG Mike
Is this true? So if i were to run all carbotech or winmax pads, bedding them is not needed?
2013 Series 10 FRS #553
Old 01-18-2015, 12:53 PM   #10
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Buy Cobalt's for track pads, no bedding required. Just slap them on and go. I love them and refuse to run anything else now.
I've got about 2 years, 30+ track days and almost 8,000 track miles on Cobalt XR2 pads, front and rear, and they are by far the best pad I've used on the BRZ. Super consistent pedal feel, no weird material transfer issues like I got with the Carbotechs, very easy to modulate, and are easy on rotors.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
Sleepless (01-18-2015)
Old 01-18-2015, 01:15 PM   #11
jflogerzi
jflogerzi's Avatar
What about street use?
Old 01-18-2015, 01:21 PM   #12
smbstyle
smbstyle's Avatar
Like any track pad, they squeal like crazy when cold, so just use your OEM pads for street use.
2013 SWP BRZ
Old 01-18-2015, 02:29 PM   #13
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
It's not an issue at all. The car stops better with track pads on both ends, but I had no issues when I only used them in front.
celica73 is offline   Reply With Quote
Old 01-18-2015, 03:07 PM   #14
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Running different pads front and rear wasn't the OPs question.
FS: Stock FR-S Seats (fronts)- SOLD ft86chick Interior Parts (Incl. Lighting) 3 01-21-2015 12:44 PM
Hawk Hp plus Fronts only? feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-30-2014 03:31 PM
Non-FI with 18x9.5 fronts? Namuna Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-06-2014 10:56 PM
Hawk HP Plus Fronts Sheldon Brakes, Suspension, Chassis 2 04-05-2013 09:32 AM
New 86.. 5 days of ownership, From Monday to Friday, 5 days of mods :D [pics!] WTF Member's Car Journals 53 07-16-2012 03:18 PM
