Old 01-16-2015, 01:16 PM   #1
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Question Hood vent mod
This seems to be pretty popular in the s2k world and i'm surprised it hasn't been done on the FRS/BRZ's since the issue with turbo and under hood temps seem to be a problem. I've looked around the forum but have found nothing similar. I think carbon hood are pretty expensive and dont think there's much weight difference between the oem and aftermarket hoods to justify the price. Any taker, diy'ers? Doesn't have to be the same, similar.. but the idea is to vent the stock hood.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 01-16-2015, 01:20 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I've been looking pretty heavily into this myself...theres a huge DIY on the s2k forum
although I've been searching for a cf vent that I could use after I cut a hole in the stock hood, and drop in the vent...
I just don't know about my skills of cutting a hole in the hood and making the edges look to clean, hence my desire for a "drop in" vent/cover
Old 01-16-2015, 01:32 PM   #3
yomny
yomny's Avatar
That would be ideal as I have 0 skills in the cutting and making look neat dept. maybe someone could start producing these. I know there's a vendor here that makes a template for nostrils.
Old 01-16-2015, 01:55 PM   #4
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I'm getting a set of these.
http://www.hoodlouvers.com/product-tag/hi-flow/
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 01-16-2015, 02:35 PM   #5
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Have you considered just getting this ( http://www.ft86speedfactory.com/rksp...hood-1496.html ) if you're not comfortable with cutting into your hood? I mean, it's pricey but you're paying for the piece of mind and looks OEM-ish.
Rabbit of Caerbonnog is offline   Reply With Quote
Old 01-16-2015, 02:47 PM   #6
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
You need air flow.. just adding a vent to our hood isn't going to do much of anything for the heat problems.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 01-16-2015, 02:48 PM   #7
yomny
yomny's Avatar
I saw the hood scoop but I always thought that was more for getting air in like the wrx and sti's have. I mentioned the vents because these would allow to vent heat while standing still and allow the high pressure on the hood to extract heat at high speeds.
Old 01-16-2015, 02:52 PM   #8
Run Away!
Ah! Gotcha. Thanks for clearing that up. But wouldn't that scope with added vents near the rear/window provide that? Sorry, if the question is ridiculous.
Old 01-16-2015, 02:58 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Not quite. You have half of the equation. You have the exit for the air, but there isn't really a good entrance for cold air to come in and flow the hot air out.
Old 01-16-2015, 03:36 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
The grill isn't a good entrance for cold air to come in?
Old 01-16-2015, 04:15 PM   #11
yomny
yomny's Avatar
Ideally you want a good entrance and a good exit. I think the car has a decent entrance already and this may work with stock under the hood temps but a bigger extractor is needed when extra heat is produced. I dont think we need to complicate ourlseves with racecar designs/componets and ideas since most of us just see street driving. I also think this would only benefit, if at all, those with turbocharged cars. I think i'll do some more searching around on the s2k forums as to how to stick the grill on the opening and jump on the task myself eventually. Just wondering what shape would look good around the center of the hood or where most turbo kit's turbine housing reside.
Old 01-16-2015, 04:30 PM   #12
continuecrushing
Originally Posted by Wonderbar View Post
Hmm, this might just be what I'm looking for...I just don't know why they each need 900 rivets to hold it on lol
Replacing hoods isn't too bad, my main issue is weight. The stock hood is damn light.
Old 01-16-2015, 04:42 PM   #13
continuecrushing
and at the end of the day it would still look cool haha
Old 01-16-2015, 05:30 PM   #14
Run Away!
Couldn't quite find the thread but IIRC, someone did a comparison between the stock hood, wet carbon (i.e. fiberglass with carbon overlay), fiberglass and dry carbon and only dry carbon weighed less than the stock hood.
FS: OEM- Hood, Trunk, Exhaust, turn signal vent, swaybar, R control arm. 305ANIMAL Exterior Parts (Aero, Lighting, Etc.) 6 11-14-2014 06:56 PM
Hood vent Jhon19lopez Exterior Parts (Aero, Lighting, Etc.) 0 03-30-2014 10:21 PM
WTT FR-S fender vent for BRZ fender vent (white) Anthony Exterior Parts (Aero, Lighting, Etc.) 8 12-02-2013 07:52 PM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 09:56 PM
