Just drive it
Drives: 13' FR-S
Tire performance same throughout its life?
I tried to search this online, but I could not find what I wanted. So question put simple: How long does tire keep its performance for?
For example, if I were to purchase 40-50% remaining tread Michelin PSS tires, would it perform the same with 90-95% tread tires? Forgot to mention that it's on track condition. |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
In the dry, I don't know.
In the wet though, I'd be willing to guess that because there's less space between the road surface and the deepest section of the tread you'll be more prone to hydroplane. |
#3 | |
In terms of tread depth, some tires get harder as you get deeper on the tread so depending upon the tire, you could have a substantial loss in performance from reduced tread depth. At the same time though, less tread means less tread squirm so you can gain some performance from that. All that is general information though and unlikely to really help you :p I would say however that Michelin PSS tires are great street tires and fairly bad track tires. The dual compound construction is great for street use but the wet compound in the center of the tire greases out very quickly. In order to use them on track you need to run them at a lower temperature than a pyrometer would tell you to use. Unfortunately there are situations where the center of the tire can still end up having major contact and result in more slide than expected which is scary. I suspect they would be alot of fun in the rain though.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#4 | ||
i'm sorry, what?
Drives: Canada
Depends on the tires Quote:
no this is why, when buying used tires, you should ask for massive discounts.
Drives: '13 WSP BRZ
I wouldn't say it makes much sense to get used tires on this car. The tires themselves are relatively cheap and you'll lose money every time you do an extra mount and balance because they only last half as long as new ones. If you can, just wait until the manufacturers are doing a rebate, I bought a whole set of Pilot Super Sports for $530 shipped with a $70 rebate.
2013 BRZ Limited 6MT, White Satin Pearl
2012 Triumph Street Triple R, Phantom Black "Treat all tires like they deserve to die!" -Chris Harris |
So elite I'm 1338
Drives: WRB Subaru BRZ
depends on the compound of the tires. I forget which tire it was, but I remember hearing about a tire that was like R comp once the tread got low enough.
-Jack Burton |
#7 | |
The Stig's German cousin
Just drive it
Drives: 13' FR-S
This doesn't mean I'm only going one direction, but rather having variety of options if any deals come by. Thank you guys for generous opinions.
#9 | |
Drives: Whiteout Scion FR-S
As mentioned above, it also depends on how and when it has been heat cycled. Also, it is important to know the date of manufacture of the tires. If they were manufactured in 2003, then the rubber has likely hardened and/or cracked so that they no longer perform as intended. Even a tire a few years old can have lower performance that a newly manufactured tire. Do you have your own tire machine, or someone who will mount the tires free of charge? If so then tires with 40% tread may be fine. Otherwise, you will lose a lot of the money you save mounting and balancing the tires, and then mounting and balancing the new tires you bought to replace the used ones that only lasted 10k miles. Finally, if these are for track use only, at least buy something like the BF Goodrich Rival, if not a full track tire.
| Tire Life and Tracking | Pokeguyjai | Tracking / Autocross / HPDE / Drifting | 10 | 12-15-2013 04:40 PM |
| Performance vs Looks Tire Question | nightfire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 05-16-2013 09:38 PM |
| Best light weight performance tire | brillo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 12-04-2012 02:24 PM |
| Azenis 615K - life and rain performance? | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-17-2012 02:55 PM |
| Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 07:33 PM |
