Old 01-12-2015, 08:33 PM   #1
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Installing Headers w/ a jack & stands
How difficult is the installation of Headers if you just have a jack & jack stands (I have these stands, http://www.harborfreight.com/3-ton-h...nds-38846.html)? Is there enough room to get the headers out or does it require jacking up the engine?
Debating whether or not I should take it to a shop or do it myself. I'm in cali so I'll eventually have to put OEM headers back on for smog kinda why I want to do it myself but I don't want it to be a big pain in the arse. That being said any tips for the install, or stuff to look out for? Only thing I read that was a beyotch were the 02 Sensors & the nuts on the overpipe, I've heard of some people snapping the studs off on their OEM headers.
I did my catback, but that was fairly straight forward and didn't need a ton of ground clearance.
http://www.ft86club.com/forums/showthread.php?t=32101
http://www.ft86club.com/forums/showthread.php?t=8121
Couple of DIYs above, everyone has a lift huehue.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 01-12-2015, 08:39 PM   #2
Nonfacter1
Drives: 2014 Ultramarine Frs
Its honestly not that bad. Installed my header (tomei uel) and a buddys (JDL) and it was pretty easy...the only thing that is a pain in the ass is making sure that you tighten the nuts all the way down...I know it seems like a straight forward thing, but make sure you go over each one like 3 times and get it to where you can't turn the wrench anymore
Nonfacter1 is offline   Reply With Quote
Old 01-12-2015, 08:40 PM   #3
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I installed headers over pipe and mid pipe using 4 jakstands. It is cozy but really works well. Once the under panel is removed the header is very accessible. Take your time and it should go smoothly.
MTCRX is offline   Reply With Quote
Old 01-12-2015, 08:51 PM   #4
Cop
Cop's Avatar
Drives: 2013 FRS
Definitely doable. One of the nuts on the header is a PITA but you should be able to do it with the right tools.
Cop is offline   Reply With Quote
Old 01-12-2015, 09:29 PM   #5
Foobar
SLO NO MO
Foobar's Avatar
No problem at all.
Old 01-12-2015, 11:57 PM   #6
ramiram1984
Drives: 2016 STi DGM
Easy
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 01-13-2015, 12:32 AM   #7
Tenament05
Drives: fast
wobbly long extension and a solid extension, deep skinny sockets and a good wrench and you're gtg
Tenament05 is offline   Reply With Quote
Old 01-13-2015, 12:37 AM   #8
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
easy as long as you know how to turn a wrench. just need extensions and everything else should come off without and issues.
be careful about over tightening o2 sensors and watch the wires, but that shouldn't be a big deal, just felt like it was one of the more fragile parts.
I'd do overpipe at the same time if you haven't already since its already there but thats just me.
Old 01-13-2015, 02:56 AM   #9
king83c10
king83c10's Avatar
Drives: 2013 FRS
I broke a stud on my OEM overpipe, once I broke the first stud I soaked all the other exhaust related bolts in pb blaster and they came off easy. Also when you install the o2 sensors put some anti seize on the threads, so you won't have issues later when you have to put the stock header back on. I did my full exhaust with two Jack stands and a floor Jack. Took me about 2 hours from start to finish.
2013 Scion FRS::Revworks uel header::Motiv front pipe::Motiv over pipe::Invidia N1::Perrin CAI::Eibach prokit::Enkie Raijin wheels::30% tint::OFT stg2uel::TWM performance M1 Abrams shift knob::Winjet black headlights::8000k OLM HID Kit::Muteki SR48 Lug Nuts
king83c10 is offline   Reply With Quote
Old 01-13-2015, 10:35 AM   #10
lucid215
took me about 2 hours and 45 minutes to do mine in my driveway with jack and stands. two of those hours i was waiting for ups to drop off my headers haha. i used a torque wrench to tighten them all down. easiest way is to remove the over pipe as well
lucid215 is offline   Reply With Quote
Old 01-13-2015, 11:03 AM   #11
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
I did mine. Not that bad. Didn't remove overpipe but did snap a stud off the stock header.
RocketBunny FRS // Phantom ESC // OFT x E85
Dallen is offline   Reply With Quote
Old 01-13-2015, 11:17 AM   #12
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I broke one off and ended up plasma torching two new holes into it for a while. Turned the stock header into an aftermarket one in minutes!
OP, the header install is easy unless it's UEL. You will want a flex socket adapter to reach one of the nuts successfully. Flare wrench sockets work great for this too. Otherwise, it's straightforward and easy on harbor freight jacks. Exactly what I used for my JDL UEL.
2016 Camaro SS is offline   Reply With Quote
Old 01-13-2015, 11:38 AM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
header location for this car is extremely easy. honda cars i worked on was worst. except S2000
Old 01-13-2015, 11:44 AM   #14
frslee
Just drive it
Drives: 13' FR-S
It was easy for me as well. One thing to look out for is the studs attached to header - overpipe connection. Studs are attached on header side. You'll have to wiggle the overpipe and possibly unbolt some rear exhaust bolts to move over pipe, so you can remove OEM header with studs on it. Other than that, it's very easy. Be care on the last bolt, so header doesn't fall on your face!
frslee is offline   Reply With Quote
jack stands oil change. Howardwei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-02-2019 11:45 PM
Jack Stands + Pinch Weld Wyattkb Scion FR-S / Toyota 86 GT86 General Forum 36 10-12-2015 03:45 AM
Japanese jack stands? Augora Scion FR-S / Toyota 86 GT86 General Forum 4 05-26-2014 12:59 PM
jack stands in the peninsula?? Shindig Northern California 2 04-28-2014 12:28 PM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
