Old 01-10-2015, 05:33 PM   #1
ohnoitsthefuzz
Drives: 2013 Scion FRS 6 Speed Raven Black
Opinion on brake rotors.
Hey guys, quick question. I'm going to Hawk HP+ brake pads front and rear. Burnt up my stockers on a track day (Already had 25k miles on them but no complaints). I was thinking about doing rotors, lines, and fluid all at the same time. I know that the HP+ can be a little hard on the rotors. My thoughts are putting the Duralast Gold series rotors on.
http://www.autozone.com/brakes-and-t...1_208602_2708/
Just over $100 bucks for rotors and a 3yr waranty. I know on past cars that if you buy their rotors (or other parts for that reason) if they need to be replaced within warranty they do it no questions asked. I would feel less bad about pads eating the rotors or doing a track day every now and again. Just looking for input on this idea.
ohnoitsthefuzz is offline   Reply With Quote
Old 01-10-2015, 05:50 PM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I thought warranty covered defective items not normal wear and tear.
Old 01-10-2015, 08:32 PM   #3
Poodles
Drives: 2015 Series.Blue
The Duralast Gold rotors are a high carbon steel rotor with coating on them to prevent rust. Honestly, the coating looks identical to the coating on the center of the rotors on our cars, but it's over the entire rotor. They're sourced from a single OEM supplier. The normal rotors are not, they're sourced from a variety of makers and it's a crap shoot what you're getting (I've seen Brembo blanks, etc). It's also why I haven't bought a set yet as the Golds are only on the fronts so far.
If you wear them out, it's covered. If you wear them out every week or something, you're going to have issues...
Nope, normal wear is covered, but not expressly publicized.
The Following User Says Thank You to Poodles For This Useful Post:
Captain Snooze (01-10-2015)
Old 01-10-2015, 08:39 PM   #4
ohnoitsthefuzz
Yeah, if I remember correctly on my WRX a few years back, I bought duralast rotors for the front and payed an extra $10 or so for the lifetime warranty. I just figured that if I did warp one, needed one turned, etc. 6 months to a year from now I'd much rather buy a new set of pads and just go pick up the new rotors. Usually the guys at my local autozone a pretty cool and won't give you any issues when you bring something in for replacement.
Old 01-10-2015, 10:26 PM   #5
You're not going to "wear them out", but you might crack em once you graduate to race pads.
If you burned up OEM pads at a track day, the HP+ is not a substantial ugprade; you're still gonna need to upgrade again.
Dave-ROR (01-10-2015), wparsons (01-11-2015)
Old 01-11-2015, 04:53 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'd just keep the stock rotors until they get near minimum thickness. I like the HP+ pads for track use on my stock s2000, love the initial bite and I never had any issues with overheating them. Definitely way better than oem, and I didn't notice any significant increase in rotor wear. Definitely worth trying IMO. If it turns out you need higher temp pads then Carbotech XP8 or XP10 should do the job.
Old 01-11-2015, 05:56 AM   #7
AJPG
Drives: 22RE, FA20, 4G63
Hi
Was thinking on some brake upgrade but no the BBK, more like cooling ducts. Already new pads, lines and fluid, no fade, at all but the rotors (front) keep getting new colors every weekend, no crack up to date.
Maybe I do NEED a BBK after all but I'm not amuse with the replacement cost of those pads/rotos...
Only 3 times at the track (work doesn't let go away all day) but back roads at least 2 times/week...
Anyway thanks and take care.
AJPG is offline   Reply With Quote
Old 01-11-2015, 11:23 AM   #8
Originally Posted by AJPG View Post
Hi
Replacement cost of Rotors/Pads on the AP Racing Sprint BBK is not much more than stock.
OEM rotors are ~125, Sprint Rotors are $165.
Sprint BBK pads are usually 10-15% higher in cost, but are nearly 2x the size.
Do you have any pictures of your rotors?
Old 01-11-2015, 01:38 PM   #9
Poodles
The stuff I've seen us cover under warranty says they likely wouldn't care
CSG Mike (01-11-2015)
Old 01-11-2015, 03:12 PM   #10
ohnoitsthefuzz
Thank you for the input, your insight on brake set ups is always nice to get. I probably used the wrong verbiage in my description. By "wear them out" I meant crack, gouge, etc. I also didn't really burn them up, like I said the stock pads have 27k+ miles on them. After this track day on friday I "burnt up" what I did have left and am needing new pads here very soon. Just figured I would swap fresh rotors onto fresh pads. I didn't know if the increase in carbon on the Duralast rotor would be a nice upgrade over OEM rotors with the HP+ pads. Like I said the car is DD, and increased brake noise with the HP+ is not an issue for me. A BBK is not warranted under my power levels and current daily routine/track track use. My thought process is that if I get the new rotors at around $110 and do somehow crack them, once I get them replaced under warranty even once, the savings alone would be worth it to me.
Old 01-11-2015, 08:36 PM   #11
The cost savings probably are, but keep in mind, that rotors generally crack during cooldown, or the first time you get on the brakes after a cooldown. If that happens to be while you're at the track (which it usually is), then you're gonna lose all that seat time.
If you go this route, I recommend you get a second set of rotors to swap on, and take it with you to the track, so that you don't suffer downtime. You can use the second set, while you get the first one warrantied, and then use the warranty set as a spare.
Don't forget to account for the time cost of your own labor. Swapping hot brakes in the desert heat sucks. If you do need to change em at the track, make sure it's all cooled down enough to be held by bare hands. Hot metal is more malleable, and it's very easy to strip/damage threads when the brake system is hot.
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Need some help... Brake Rotors Lebby83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-05-2014 07:07 PM
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 10:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
