Old 05-19-2014, 03:28 PM   #1
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Need some help... Brake Rotors
Hey everyone - I am looking for some suggestions on any performance brake rotors in the OEM size that will work with the stock/oem brake caliber.
Car is a 2013 BRZ that is tracked. We already put some performance pads on it, but pretty sure we warped one of the rotors this past weekend at the track. We know we will do a whole big brake kit one day, but we are not there yet.
Any ideas/comments would be greatly appreciated.
Thanks!
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 05-19-2014, 03:52 PM   #2
OrbitalEllipses
Drives: Attitude
@CSG Mike and everybody else will say to use Centric blanks...that's your most cost effective solution. Your issues won't be solved with a rotor, they'll be solved with better technique and better equipment with more thermal capacity.
What pads and what kind of course(s)? Wonder if you glazed the pads - a possibility if they weren't up to the heat you put through them.
Old 05-19-2014, 03:59 PM   #3
Lebby83
Brake pads are Ferodo, I believe the DS2500. Track was Pocono North course, 5 turns, 4 of which are hard braking. My brother was driving the car (he has 50-60 DE days under his belt). I have previously used the BRZ (with the same pads) at Thunderbolt this past March with no issues at all.
Rob
2016 VW Touareg TDI
Old 05-19-2014, 04:51 PM   #4
CSG David
CSG David's Avatar
Look into using race compound pads than the street pads. DS1.11 or DSUNO Ferodos are the minimum from the Ferodo lineup.
I'd look into using the same compound front and rear. Carbotech XP12, Project Mu Club Racer, PMU 999, Winmax W6, etc. should be used for your application.
Just use standard blank rotors for your application.
Old 06-05-2014, 08:07 PM   #5
RB Performance Brakes
RB Performance Brakes's Avatar
Drives: BRZ/FRS
Thanks!
We offer a OE big brake kit that enables your stock caliper to use our 322x25mm rotor, helping reduce brake fade. Also, the rotor that comes with this kit features a reinforced rib that increases rigidity allowing the rotor to better prevent warping if tracked.
If you have any questions feel free to ask!
-Chris
RB Performance Brakes is offline   Reply With Quote
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
What brake caliper and Rotors will fit? gdrider77 Tracking / Autocross / HPDE / Drifting 0 10-08-2013 07:19 PM
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 11:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
