Old 01-08-2015, 03:08 PM   #1
trsiidno
Drives: .
How much boost
I just got my car turboed and am wondering how much boost you guys are running in your frs/brz.
trsiidno is offline   Reply With Quote
Old 01-08-2015, 03:51 PM   #2
robr
Drives: 2013 FRS, with boost by ATS Racing
Need to be more specific. What turbo? What turbo kit, if one? What fuel? What fuel system upgrades?
I run a conservative 11psi on a PTE5558 on E85. I don't have a "kit" setup.
People run 5psi on AVO kits.
People run 1 bar on AVO kits.
See where I'm going with this?
robr is offline   Reply With Quote
Old 01-08-2015, 03:52 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
OVER 9000
The Following 10 Users Say Thank You to King Tut For This Useful Post:
akash_ (07-04-2015), dpgfunk (01-12-2015), hmong337 (01-08-2015), P&L Motorsports (01-08-2015), R2RO (07-02-2015), STV3 (01-12-2015), swarb (01-08-2015), Whatabouteggs (01-08-2015), woode (01-08-2015), zdr93523 (01-09-2015)
Old 01-08-2015, 04:07 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
OVER 9000
Micro Pascals right?
Old 01-08-2015, 04:08 PM   #5
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
10psi Kraftwerks C38 (94 octane pump) really conservative tune here.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-08-2015, 04:12 PM   #6
Dream20b
Y u do dis?
All the boosts.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 01-08-2015, 04:14 PM   #7
trsiidno
Drives: .
I wasnt really asking what to run on mine im just seeing what other people are.
Im running 10-11 psi on a 60trim garret turbo 93 oct stock injectors and pump 310whp
but I daily drive so I ussually set it at 8psi
Old 01-08-2015, 04:31 PM   #8
sw20kosh
Drives: 2013 Black FR-S
You are gonna need to change out those injectors before you can think about upping the boost.
Also, I wouldn't run anymore than the boost you are already runnin on pump gas.
Go E85 if you want more.
Old 01-08-2015, 04:32 PM   #9
trsiidno
Drives: .
I wasnt gonna go past 11 on stock injectors and pump. But I have a few e85 stations around me. I daily drive so what is gonna be the pros and cons of e85. And youre saying after I get injectors and pump I shouldnt run any more boost on 93?
Old 01-08-2015, 04:53 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Nope more than that.
The Following User Says Thank You to King Tut For This Useful Post:
Calum (01-08-2015)
Old 01-08-2015, 04:57 PM   #11
robr
Gotcha. Still a rather vague question. 11psi from Turbo A isn't the same as 11psi from Turbo B.
As to E85, the only real "negative" is fuel mileage. But you can lean out your cruising AFR a good deal to make it back some. I average ~24mpg highway on E85, ~21mpg mixed, both with a good amount of boost usage. So it's certainly not terrible mileage.
And I wouldn't increase your boost on pump gas regardless of what pump and injectors you go to. On E85, yes, turn it up a bit.
Old 01-08-2015, 06:18 PM   #12
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
In for the answer. This topic hasn't been covered yet; I am curious as well.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 3 Users Say Thank You to woode For This Useful Post:
Boofneenee (01-08-2015), Dream20b (01-11-2015), raven1231 (01-08-2015)
Old 01-08-2015, 06:39 PM   #13
sw20kosh
lol
Old 01-08-2015, 07:28 PM   #14
kbogarto
Drives: 2013 BRZ limited WRB
7.2 psi
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following User Says Thank You to kbogarto For This Useful Post:
Boost up my car bomexq Forced Induction 66 03-10-2014 07:32 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
E85+boost subatoy Forced Induction 5 11-06-2012 11:55 AM
