Old 01-07-2015, 09:29 AM   #1
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
Perrin motor mounts
Thinking about adding these to my list of parts to order for the spring. Does anyone currently run these? If so, how much to have them installed? I imagine they need do use an engine hoist and whatnot? My friend had these installed on his 06 mustang and having driven it myself before and after the install, I notice a difference in both a little added NVH (a negative) but added engine "feel" and throttle response (positive). I did try to search the forums but crazy amounts of bs came back. The only thing that makes me wary is the fact that the interior on our cars isn't the highest quality. More vibration may cause the door panels to fall off blues-mobile style. Any tips would be appreciated.
BRZBlack is offline   Reply With Quote
Old 01-07-2015, 09:56 AM   #2
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
The STi Group-N mounts are a nice compromise of stiffer mounts but not a significant increase in NVH. They're a little pricey though.
If you haven't done it already, the Whiteline subframe bushing inserts give a similar feel (less drivetrain slop) but very little NVH, and are inexpensive. The differential mount inserts are even better, but added a bit of noise in my case.
JozhGoober is offline   Reply With Quote
Old 01-07-2015, 10:48 AM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I run them, no issues with things falling off over the past year. No engine hoist needed, the install can be carried out using a jack on the corners of the oil pan. As for NVH, it will depend on your sensitivity but I run poly (or aluminum) bushings everywhere and it doesn't bother me.
Decay107 is offline   Reply With Quote
Install Day - P&L Equal Length Header and Perrin Motor Mounts F1point4 Engine, Exhaust, Transmission 80 04-24-2021 04:28 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
Perrin Motor Mounts ramiram1984 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 12-16-2013 12:13 PM
WTB Perrin Motor & Tranny Mounts ReThink Want-To-Buy Requests 0 12-02-2013 02:46 PM
PERRIN MOTOR MOUNTS FR-S & BRZ Just arrived PICTURES gmookher Engine, Exhaust, Transmission 43 01-17-2013 03:30 PM
