Drives: WRB BRZ
Whiteline Subframe Bushings problem
Was attempting to install these yesterday but couldn't get the subframe to align with the holes when the inserts were in place. Passenger side went in easy but driver side gave me problems. Tips or tricks to doing this? Ended up removing them and the subframe went in easily.
i'm sorry, what?
Drives: Canada
did you spread the torque evenly or did you put the bolts in on one side before you went in on the other?
Drives: WRB BRZ
Got one bolt slightly threaded and tried to thread the other with no luck . Wouldn't line up. Then i also tried to tighten the passenger bolt to see if it would aid in getting the other in, same problem.
Unless I'm misunderstanding the question. |
Drives: WRB BRZ
Car was raised on jack stands. Would it have worked/helped if I had the cars weight on the wheels. (Ramps)
That Guy
Drives: 2013 asphalt FRS MT
Check to see if the inserts are concentric.
Sent from my samstone |
Drives: Sterling BRZ Ltd
Its certainly a trick for the install. I wouldn't say its at all the fault of the whitelline bushings.
Just have to keep trying and do a bit a time on each corner, it took me a few tries but then the stars align and it goes right in.
I haven't done these yet, but would it help to use the jack to help lift the subframe? Maybe a second person to operate it while you're under the car.
#8 | |
Drives: WRB BRZ
Correct I am using the jack to support the subframe. Lifting and lowering subframe as needed. The jack allows for the passenger side to get raised in but can't seem to get driver side aligned. When bushing is not installed the 1/4 inch or so space without the bushing allows the jack to center into the bolt hole. |
| Whiteline rear subframe bushing install... | fl_speed001 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 07-11-2020 12:29 AM |
| FS: Whiteline positive shift (trans mount) and subframe bushing kit | twincamRob | Transmission and Driveline | 9 | 02-17-2014 01:17 PM |
| whiteline rear subframe inserts | charged86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 05-18-2013 09:20 PM |
| WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 05:15 PM |
