| Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
Drives: 2013 GBS BRZ Limited
WHY do I get WIFI reception inside my microwave?
So I have a gopro Hero4 with WiFi.
I can see the video on my tablet, and first thing we did was to see if the fridge light really DOES go off when you close the door (It Does) Next we were just curious so we put it in the microwave (NO we didnt turn it on), but we could see ourselves through the front window even though the door was closed. I thought that microwave ovens were supposed to block all of the RF......
Drives: 2014 Toyota GT86 Pearl White
Microwave ovens use around 2.45 Ghz, which can be the same as some Wi-Fi, but there are other higher frequencies that Wi-Fi uses. Maybe the Hero4 is using one of those higher frequencies?
| The Following User Says Thank You to Hydaral For This Useful Post: | stugray (01-04-2015) |
Wow, parties around the Stug house must be a blast!
(I joke but would probably have the damn camera in the weirdest conceivable places)
Drives: GR Corolla
My WiFi signal gets disrupted when I turn on my microwave. Quite annoying.
#5 | |
As for the Microwave: It is supposed to block all microwave frequencies. Microwave oven freq is at 2.4 GHz, which is a wavelength of about 12 cm (4.75 In). In theory, the microwave RF shielding should block frequencies on and to either side of the Microwave primary frequency, but seems it isnt. The freq of wifi is 2.401 to 2.473 GHz. So the only explanation is (as @Hydaral says) that the WiFi is using some of the higher bands. |
| The Following User Says Thank You to stugray For This Useful Post: | Tcoat (01-04-2015) |
not playing cards
The microwave is not a perfect Faraday cage. It's meant to shield the signal enough to keep the field strength below some level determined to cause interference with other devices.
There's a lot of gain at the front end of the receiver. edit: Wait, aren't you an electrical engineer?
Drives: 2014 BRZ LTD WR Blue Pearl
most devices are wireless n nowadays. operate at 5gz frequency.
Older bg protocol is 2.4gz |
| The Following User Says Thank You to bee-jay For This Useful Post: | f0rge (01-06-2015) |
Drives: 2006 Cayman S, 2007 Outback 2.5i
N works on both the 2.4GHz and 5GHz bands actually - 2.4 tends to have slightly better range, but 5 has less interference typically (since there are a lot more older routers on 2.4 than new ones on 5). 802.11a is 5GHz only, as is 802.11ac, while as you said, 802.11b and 802.11g are 2.4.
T64-416Ax3=13,140shp
Drives: 2002 AP1 and 2015 F-150 EB (DD)
Warning: NERD ALERT.
#10 |
Kuruma Otaku
Sorcery.
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | Tcoat (01-06-2015) |
| Radio Reception is poor? | NOHOME | Electronics | Audio | NAV | Infotainment | 11 | 05-01-2019 02:07 AM |
| Hawaii HD channels or not good reception? | InspGadgt | Hawaii | 4 | 07-13-2014 07:44 AM |
| BRZ's very poor reception | theredtape | Electronics | Audio | NAV | Infotainment | 3 | 10-05-2013 01:23 PM |
| Terrible radio reception? | ngabdala | Electronics | Audio | NAV | Infotainment | 11 | 10-27-2012 05:57 AM |
| Any problems with voice recognition and sat phone reception? | WMS | Electronics | Audio | NAV | Infotainment | 1 | 06-25-2012 06:45 PM |
