Drives: WRB BRZ
AFR Incredibly high?
Here is the data map for my OFT stage 1 tune. I'm currently running a perrin 3" BIGMAF Intake and I have used their set MAF scaling. I'm not sure how useful this info on this data map are but it seems like my AFR and LTFT are off with my LTFT running almost at -14 and AFR in the low 20's.
From what I've read AFR should be around 14.7 and LTFT values should be no more than 10. I'm sort of a noob when it comes to this, but with this low of LTFT readings I'm running rich? If someone can clarify if these are normal readings for this tune or if I need to correct something that would be helpful. Lastly, It has been over 100 miles of normal driving and I'm still getting the dead spot in the pedal. I'm assuming I screwed something up somewhere, I just don't know where. http://datazap.me/u/speedfromswede/b...=0&data=1-8-10 |
AFR of 20 happens when you lift off the throttle. This is normal.
LTFT at -13 is definitely not normal though. You'll want to correct this.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
Drives: WRB BRZ
Thanks for the feedback. What would be the best way to correct fuel trims? The only thing I can think of is a vacuum leak or rescaling the MAF.
I'd double check your MAF scale is the correct one from Perrin -- I'd expect you to be within 5% when using the one they provide.
Other than that -- yea, check for a leak or a dirty MAF sensor. If it's a new install, oil might have slung off the filter if you didn't give it a wipe down before putting it on.
+1 on what @phrosty said
maf scaling here ans 3" perrin scale at bottom of post http://www.ft86club.com/forums/showthread.php?t=64790 . |
Drives: WRB BRZ
Double checked the MAF scaling and it is the correct one from Perrin. Looks like I'll have to check for leaks and my MAF sensor. Other than that, would you recommend I use vgi custom maf scaling? http://www.romraider.com/forum/viewt...p?f=32&t=10481
#7 | |
sometimes takes a couple of attempt to get scaling corrected when its that far off. |
#8 | |
Drives: WRB BRZ
The next thing was for vacuum leaks, unless there is one further up the intake towards the filter, I couldn't find any. I took off the inlet tube to the throttle body and re-clamped it. Likewise for the inlet tube to the intake itself. Wasn't any different in the LTFT readings, around -7 at idle and -12 at 2000 rpm until release of throttle it decreases again. The thing that is peculiar is the STFT at idle being around 1.5 and at constant throttle being 0. |
You're like 15 minutes from Mach V Motorsports in Sterling. Dan can probably help you if you don't get it yourself.
| The Following User Says Thank You to White64Goat For This Useful Post: | SpeedFromSwede (01-03-2015) |
#10 | |
log about 30 minutes of smooth driving at varying rpm and loads, and not too much idling. feed that into vgi program and do the closed loop scaling. once you have that sorted do the open loop wot scaling by logging 3 or 4 wot runs from 2000-7000 |
#11 | |
Drives: 2013 Asphalt FR-S
Be sure to account for the short term trim as well, Most spots your combined short and long term trim error is less than 10% there is probably a small region where the maf scale is off that needs to be adjusted, leading to long term trim build up and short term trim correction when outside of the area that needs to be re scaled. You also need to log throttle position.
~Namaste~ |
#12 |
Señor Member
What tune are you running OP?
1974 TA22 Celica
2013 86 GT |
#13 |
Drives: WRB BRZ
#14 |
V1.5x OFT stage 1 tune or V2.062 Stage 1 OFT tune. The V1.5 had offset maf scaling. If you not already use the V2.062 stage 1 rom if your going to edit maf scaling. Last edited by steve99; 01-06-2015 at 07:15 AM. |
| High rev | Hempo | Engine, Exhaust, Transmission | 13 | 12-23-2014 06:01 PM |
| How high can i get my rpm in a new car? | 10series#1969 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 02-14-2014 01:52 AM |
| Why is my GoPro battery life so incredibly bad? | qoncept | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 05-20-2013 01:43 PM |
| High Beams | DC-FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-12-2013 10:44 PM |
