| Software Tuning Discuss all software tuning topics. |
#1 | |
OpenFlash Tablet will not connect to OpenFlash Manager
I have an OFT Tablet that i cannot get to work on 3 seperate computers (using different USB cables). Every time i get the exact same error. Using the latest OpenFlash Manager v 1.06.
![]() Quote:
#2 | |
Drives: FT86
That version of OFM is way out of date you need to download and inatall the latest version 1.15.1 from here http://openflashtablet.com/Automotiv...%20Manager.zip you will also need to download and install template file http://openflashtablet.com/Automotiv...omized%204.SLT web page is here make sure you either clear cache of hit controlf5 or click refresh while holding down control key. http://openflashtablet.com/Automotiv...ads/index.html |
#3 |
Drives: Hot Lava FR-S
i got one better for you, mine will connect but will not erase data from it not even off the shelf maps that i load to it.
#4 | |
Drives: FT86
If you want to erase tunes go the the "Upload Data" tab. then click the red X next to the tune file you want to delete, then you can upload a new tune to that slot. There are 5 tune slots you want be able to erase your stock tune (in the protected slot) unless you do the unmarry procedure. The Erase tab is only used when you want to "unmarry" the OFT from your car. The Erase function only works if you have written your stock tune back to car. You dont need to "ERASE" unless you want to unmarry tablet. If it has got itself into some sort of knot then you could try writing back your stock tune to car. then use ERASE to delete everything Then READ your stock tune again see the OFT TIPS link below for more info |
#5 |
Thanks for the quick reply Steve, i had it erased on Thursday and was making a video to show that it was "unmarried" and that it worked for a guy wanting to buy it. guess i will have to give them a call on Monday.
#6 | |
#7 |
Drives: 2015 FR-S (Halo)
I had this exact problem too - but 1.06 is what is listed on the website under downloads. If it's a broken version, they shouldn't still link to it and not have a link to 1.15. I hate to revive an old thread but it was kind of hard to find this info and it should probably be fixed.
#8 | |
Drives: FT86
you must be getting cached versions of web pages. |
#9 |
Yeah I fixed it too. If you Google OpenFlash Manager, their page w/ 1.06 is the first result. They should probably remove this page from their sitemap. Thanks though!
#10 |
Well, it's been a few years and I'm now getting the error message, but it's slightly different. it says "Sequence Contains no matching elements". I've removed, downloaded and installed a new version, but same issue. What is really weird is that I just used it last week to upload a tune file and I don't think I updated anything on the PC or the software since. Just tried to upload a new tune file with some adjustments.
#11 |
Drives: 17 86
Shot in the dark, but are you using a USB 3 connection? I had all sorts of errors until I started using USB 2.
| OpenFlash Manager 1.14 Problem | Apoc | Software Tuning | 30 | 12-10-2014 12:14 PM |
| Openflash Tablet + Openflash Header | smellslikecurry | Engine, Exhaust, Bolt-Ons | 9 | 12-01-2014 06:20 PM |
| OpenFlash Manager 1.07.1 | Mad_Hatter | Software Tuning | 24 | 04-24-2014 06:46 AM |
| Now Available: OpenFlash Manager 1.04 | Shiv@Openflash | Software Tuning | 37 | 12-14-2013 10:02 PM |
