Old 01-02-2015, 06:27 PM   #1
dp1
driving smoother faster
Drives: Sold
Enkei RPF1 rim width/offset for Nitto NT01 235/40-17 tire?
Measured rim width for 235/40-17 NT01 is 8.5".
Light 17x8.5 rims are not plentiful and good ones can be expensive (i.e., Volk TE37). I don't want to break the bank if I get wheels off on track and need replacements, so going with RPF1.
HPDE (track) and AX use.
Running -3f/-2.5r camber at just under 1" drop, Ohlins R&T, AP Racing Sprint BBK.
I know that NT01 will fit both 17x8 and 17x9 rims. I think that a little wider is better (when in between) to handle tire flex during hard cornering and to avoid having to run higher pressures to compensate.
Looking at 17x9 +35.
Not sure if I would need spacers with +45, may be tight but would most likely clear BBK and wouldn't rub - want to make sure that there is no rubbing anywhere when pushing on track/AX.
17x9 also fits 245/40 size perfectly so I can try Hankook Ventus RS-3 next.
Any reason to go with +45 over +35?
Also, if someone in tri-state has black or bronze RPF1 in 17x9 +35 or +45 for sale (no repairs or significant curb rash, straight), let me know what you have.
Thx
dp1 is offline   Reply With Quote
Old 01-02-2015, 06:52 PM   #2
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
are you asking about 17x8 +45 vs 17x9 +35? becuase I thought we already got you covered in the 17x9+35/45 over here
here are their confirmed fitments from their website
Enkei RPF1 17x7.5 +48
Enkei RPF1 17x8 +35
Enkei RPF1 17x8 45
Enkei RPF1 (very tight fit, but works) 17x9 +35
Enkei RPF1 18x9.5 +38
17x9 +45 will not fit the sprint kit without spacers
AP racing fitment thread
Essex fitment guide
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
dp1 (01-02-2015)
Old 01-02-2015, 08:59 PM   #3
dp1
Drives: Sold
Enkei RPF1 17x8 +35
Enkei RPF1 17x8 45
Essex fitment guide
You got me covered here and there, thanks again
Should have just added this to the other thread - since that post, somebody (quite experienced with our cars) mentioned to consider 17x9 +45 and spacers for my setup as opposed to +35...didn't have a chance to discuss why. Thoughts on that?
I am hoping for feedback about 17x9 RPF1 offset from those own these rims and push their cars on track/AX and use 235/40 or 245/40 tires, and have coilovers, and use -2.5 or more negative camber all around.
I am also hoping for feedback from those who know from track/AX experience if 17x9 is a better fit than 17x8 for NT01 in 235/40 size that's intended for 17x8.5 rim width.
I see that +35 clears the BBK without spacer, and I don't mind using spacers to get the most optimal setup for +45.
I don't care about the looks (poke, etc), only fit/performance.
Much appreciate feedback
The Following User Says Thank You to dp1 For This Useful Post:
G-Man (01-02-2015)
Old 01-02-2015, 10:32 PM   #4
G-Man
G-Man's Avatar
I cannot think of any benefits to using spacers at all unless you have clearance issues or already own the +45. I run 17x9+35 weds tc105n with no problems on 245/40/17.
Maybe there is something to getting the extra clearance because they are afraid of how close they are to the BBK, but AP racing and i think the whole RPF1 +35 thread says they have never had anything hit maybe someone else can chime in on anything that is being forgotten.
dp1 (01-02-2015)
Old 01-02-2015, 11:14 PM   #5
dp1
Drives: Sold
Great feedback, thanks
I think that I read that +35 can rub in the rear a little with no or little negative camber (I believe it was on 245/40, will check), and I'm looking at -2.5 to -2.8 rear camber on a 1" drop, so probably not a concern in the rear. If I got +45, there should be no rubbing with this camber in the rear, without spacers.
I wonder if 10mm spacer with +45 in the front gives the same clearance as +35 with no spacer.
Sorry to be a pain but want to make sure I do this right the first time, as it's easy and safe to use 5-12mm spacers for fine-tuning but with +35 I'm stuck if it rubs on track.
I already have 235/40-17 Toyo RA-1 on 17x8 RPF1, shaved and heat cycled and with 3-4/32 tread. They worked really well on track and AX, with and without 12mm spacers, but they get a little squirmy at the limit...it may be the driver and JRSC
Got NT01 to see if breakaway and recovery works a little smoother.
Thanks again!
Old 01-04-2015, 12:52 PM   #6
dp1
Drives: Sold
I'll try again...
If you:
- own RPF1 in 17x9 and 235-245 width tires
- track the car (drive over curbs, etc)
- have AP Racing Sprint kit
- have coilovers
- have at least -2 deg camber all around
- experience no rubbing
...which rim offset did you go with (+35 or +45) and what spacers are you using, if any? Thx
Old 01-04-2015, 10:20 PM   #7
+45 is lighter than +35, even if you add the weight of spacers and extended studs.
You WILL need spacers with the +45 to clear the AP kit.
+45 in 5x100 is less common than +35.
Disclaimer: I run a 17x8.5 +55 wheel on my personal car... but they're BBS :p
Old 01-04-2015, 10:36 PM   #8
dp1
Drives: Sold
Thank you @CSG Mike. What size spacers to clear AP BBK? Already have 12mm spacers but can get different size if needed.
I am also looking at potentially buying 17x8.5 rims, the best size for 235 and many 245 tires...unicorns are easier to find unless one spends over $2,500 on a set...still looking. I have a feeling that NT01 (thanks for the PM) in 235 width will serve me very well for track and AX.
Old 01-05-2015, 03:09 AM   #9
I have no idea... but the 12mm should be fine.
You should consider the Maxxis RC1 in 235 as well; they're faster than the NT01 in cooler weather.
dp1 (01-05-2015), Sleepless (01-24-2015)
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 01:31 AM
Any vendor willing to make a GB of Enkei RPF1 in 17x9 +38 offset?? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-30-2013 01:24 AM
Enkei RPF1 17x7 42mm offset brz7400 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-08-2013 07:26 PM
GOLD Enkei RPF1 17x8 5x100 45mm Offset JDMenrique Wheels and Tires 5 11-08-2012 06:08 PM
