Old 12-28-2014, 10:36 PM   #1
QuickShift86
QuickShift86's Avatar
Drives: 2013 White FRS
Factory Rev matching or...
Hello all! new to the forum but been reading all the great posts here at FT86club. Everytime I needed information on the frs, it always seems like i'll find it here. I hope to contribute with my own experiences. So just got my hands on a used, 2013 whiteout, MT FR-S. Came with 17k miles on it. Driving it around, I gave a go at practicing my heel-n-toe skills or lack thereof. Starts off good, I match the revs, no unsettling of the car. Tried it a few more times but the last time, I goof the blip. Side of my foot slipped off the accelerator. Lo and behold the car blips itself and matched the revs. I'm baffled, maybe I gave it enough gas to make it work. I tried it again, just this time without throttle blip going from 4th to 3rd. Pushed in the brake pedal, clutch, downshifted, RPMs climb, release the clutch, smooth transition, no tire screech. I then tried it from 3rd to 2nd, there it is. Rev, set, matched. Kind of a bummer, thought I was actually getting better at it but then again i'm intrigued.
So this led me to search the world wide web. Found nothing at all. I know that the only AT have rev matching and the MTs does not. I know that EcuTek supports rev matching but I really don't know if that could be the source. I don't even know where to poke around the car to look. What should I look for?
A few things that the previous owner did was swap out the emblems with toyota emblems. Also the factory wheels were plasti dipped black which I peeled off. Given the subtle appearance mods, that kind of gives me a reason that it could be aftermarket. The car is mechanically sound, I test drove a BRZ before I bought this car so I have an understanding of what I'm looking at. I bought the car from Toyota, came with the factory warranty and lifetime oil change. I'm assuming that if it is aftermarket, the dealership would know about it. So what do you all think? Any help would be greatly appreciated. Thanks!
QuickShift86 is offline   Reply With Quote
Old 12-28-2014, 10:52 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
As far as I know...only the automatic FRS has a built in rev matching. The manual doesn't.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Packofcrows (10-16-2015)
Old 12-28-2014, 11:01 PM   #3
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Ecutek tune can have rev matching enabled. Maybe the previous owner had it tuned.
post_break is offline   Reply With Quote
Old 12-28-2014, 11:04 PM   #4
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
Is this your first MT? The transmission will go up to the correct speed without rev matching but it puts wear on the clutch and wears out your synchro's too. In generally it's just a big no no. The 86 doesn't have rev matching, the only common mt cars I know that have it is the 370z and c7 corvette.
EDIT: if you bought it used and ecutek can enable it, it may be tuned. That would be my guess
Chad11491 is offline   Reply With Quote
Old 12-28-2014, 11:16 PM   #5
QuickShift86
Thanks guys. Not my first MT, had civics/integs all in MT. What I'm describing is not the engine revving up to match wheel speed during improper downshift. Theres is undoubtedly an increase of revs as soon as I engage the clutch, no throttle. if it is tuned, how would I go about checking?
Old 12-28-2014, 11:21 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
[ame="https://www.youtube.com/watch?v=TahBDnCv5FE"]Testing new BRZ/FRS EcuTek RaceRom Features - YouTube[/ame]
As much as everyone hates john visconti I'm pretty sure all the ecutek tunes use the cruise control as a control switch to choose maps
Old 12-28-2014, 11:21 PM   #7
post_break
post_break's Avatar
Start the car, pull back on the cruise control stalk and hold it, see if it goes to 1k rpm then let go. If the tach goes to 1k rpm move the stalk up. If it goes to 1k, 2k, 3k, and 4k, those are the 4 maps. It's tuned with ecutek.
When you're done with testing move the tach back to 1k and pull back on the stalk to set it. Keep it on map 1. You have no clue if the other maps are for different fuels, etc.
If you get confused watch some youtube videos on how to change maps with ecutek.
The Following User Says Thank You to post_break For This Useful Post:
FRSBRZGT86FAN (12-28-2014)
Old 12-29-2014, 09:19 AM   #8
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Depending on how fast you're pushing the clutch in, this is normal and expected behavior. Or at least it is on my stock FR-S.
Jyn is offline   Reply With Quote
Old 12-29-2014, 11:03 AM   #9
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Your stock frs automatic??? Manual does not rev match stock the rpms will drop to zero with clutch engaged and gas disengaged, unless tuned with rev matching.
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 12-29-2014, 01:49 PM   #10
QuickShift86
Confirmed!
Thanks 86FAN, just watched the video and did exactly that. It does in deed has Racerom with 2 tune modes.
Before even finding out, it the car was set in tune 1. I Switched to 2 and completely different engine characteristics. Not knowing what it does, I didn't keep it there long. Thanks guys for all the help. Now I guess the only thing left to do is find out what the tunes are.
The Following 2 Users Say Thank You to QuickShift86 For This Useful Post:
FRSBRZGT86FAN (12-29-2014), Tcoat (12-29-2014)
Old 12-29-2014, 04:32 PM   #11
FRSBRZGT86FAN
I'm pretty sure you'll have to buy a tune and ecutek license in order to even mess with them. I must say that's a pretty good easter egg to find
Old 12-29-2014, 04:37 PM   #12
Koa
it's not a "big" no-no, but it definitely isn't a best practice. The synchro wear by doing that isn't going to be significant if you're a good manual driver all around- the gearset would most likely explode before the synchro gets worn from not rev matching all the tie
Old 12-29-2014, 04:52 PM   #13
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Wow lucky buyer!
Congrats on the new purchase.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 12-29-2014, 04:59 PM   #14
post_break
post_break's Avatar
He'll need to buy a tune and a cable, but the license is on the ecu. He just saved $300+.
Matching HID's and DRL's red_ZN6_4_you Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2014 02:09 PM
Openflash rev matching cjsporl1996 Software Tuning 6 12-18-2013 11:04 PM
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 01:03 PM
AT BRZ - stopped rev matching... ray7792 BRZ First-Gen (2012+) — General Topics 2 10-31-2013 07:24 PM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 05:48 PM
