Drives: Toyota GT86
Home made cold air intake uppgrade, for oem box.
When I installed my perrin oil cooler.
I came up with the idea to mod the snorkel to the airbox, as everyone else has done, who did not want to buy a ready-made from HKS. But I took it a step further and this is how it kame out ![]() The arrow on the tape pointing towards the end of the impact member, is where the air hits to be brought up to the snorkel through the air ducts on the beam and in the styrofoam. ![]() ![]() so let's make it better ![]() ![]() ![]() ![]() Then cut and glued bits I got over from polystyrene, to obtain a smoother passage. ![]() ![]() ![]() ![]() Then I started the manufacture of aluminum plate that was bent into different sections to control the air and get some more air up to the filter. ![]() ![]() ![]() ![]() ![]() Then did a version 2.0 of the plate, which was not as badly damaged and finer bent and even a bit longer, modded although the snorkel to fit into the new cold air scoops. ![]() ![]() ![]() One can see that the bottom of the guide plates fall a little further down than the original air passages in the crash beam.
FR Noob
I think if you tilt the bottom forward to certain degree it'll create a "scoop" to direct the air upward even more.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in |
Drives: 2014 Pearl BRZ Limited
IAT's before and after would be nice to know. I've often wondered about doing something like this..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
Drives: waiting on a 2021...
LOL, I think the best you'll get is the ever reliable "butt dyno"...and of course it'll show a big improvement.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| The Following User Says Thank You to zooki For This Useful Post: | Fast_Freddy (10-13-2015) |
The Mechanic
Drives: Civic Turbo,FR-S
http://www.ft86club.com/forums/showthread.php?t=22894
i did somthing like that but tubular with a velocity stack. here you can see it in a few pics down. it felt faster on the highway but had waaayyy to many rocks and bugs up at the filter so i took it off
| The Following User Says Thank You to Grip Ronin For This Useful Post: | JohnJuan (12-29-2014) |
Drives: Toyota GT86
Drives: Toyota GT86
#10 |
Drives: Toyota GT86
Ha ha, unfortunately, will probably never happen, after that I'm just a regular person and not some company that makes stuff
![]() so to get some how of proof that they work, I cut very thin fringe of paper and taped over the original channels and drove with a fan in the front, to see how much they rose up, and did the same with new channels and the plates and they were actually more flow (hillbilly science)
#11 | |
Drives: Toyota GT86
![]() Do not believe that the butt dyno will notice much. |
#12 |
You know that , at speed, the entire area in front of the radiator is a high pressure area, right? It doesn't really matter if the opening faces the front or the side, the pressure is the same. Years ago I tested a ram air setup with the scoop
directly in the airflow(under the front bumper). At 100 MPH I showed a positive pressure of 4 inches/H2O(about 1/7th of a pound) If you look up Grimmspeed's testing of the stock intake tract you'll see the stock snorkel actually aids in flow. Additionally, many people have observed that at any speed other than standing still the intake air temp & ambient air temp is usuall within 2-3 degrees of one another with the stock intake system in place. Nice fabrication though. 👍
| Home Made Header : ACE Muffler | AceHeader-MT | Engine, Exhaust, Transmission | 44 | 01-26-2015 03:31 PM |
| Home-made single exit exhaust cover | ML | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 09-18-2014 10:42 PM |
| Home made adjustable end links anyone? | smbstyle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-11-2014 05:57 PM |
| BRZ Drifting - Home Made | hypermax | BRZ Photos, Videos, Wallpapers, Gallery Forum | 12 | 04-01-2013 10:10 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
