Drives: 13 White MT FR-S
Home-made single exit exhaust cover
I made this in my garage in about 20 minutes, and under $10. I got a thin cutting board thing from target for like $1, and some 3m heavy duty double sided tape. Then I took a blank piece of paper and put it over the empty exhaust hole. With a crayon I colored over the edges of the lip, then put the cutting board over the paper and cut along the lines the crayon made. Then just put thhe 3m tape alo the inside off the cut plastic you just made, and then stick it on over the hole.
| The Following User Says Thank You to ML For This Useful Post: | raven1231 (08-11-2014) |
Drives: FRS
looks pretty clean for a diy job and cost. i wonder how it would hold up over time after driving on freeways for awhile since it's just 3m tape.
This pic is after about 2 weeks
| The Following User Says Thank You to ML For This Useful Post: | 8R6 (08-11-2014) |
Still on there tight
Veteran RallyCrosser
Drives: 10 Series FR-S, 95 Escort Rally Car
I might just have to try that, thanks!
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal 2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive |
| SINGLE EXIT EXHAUST | karma003 | Engine, Exhaust, Transmission | 163 | 06-28-2018 02:48 PM |
| Another project teaser. Exhaust hole covers for single exit exhaust! | Wonderbar | Cosmetic Modification (Interior/Exterior/Lighting) | 57 | 05-30-2014 01:46 AM |
| single exit exhaust | jdmblood | Engine, Exhaust, Transmission | 24 | 09-07-2013 04:27 PM |
| For Those of Us with a Single-Exit Exhaust | naikaidriver | Engine, Exhaust, Transmission | 12 | 09-05-2013 01:20 PM |
| Single exit exhaust? | Sonydigital | Engine, Exhaust, Transmission | 24 | 07-20-2013 11:26 PM |
