Old 12-24-2014, 12:01 PM   #1
ItsYousefBro
ItsYousefBro's Avatar
wheel wobbling, HELP!
So a couple of days ago avoided a car hitting me and I slid against the guard rail. I few (not big) dents and scratches. Since then the wheel wobbles at all speeds. There isn't any wheel damage. I inspected the car myself and I don't see anything broken or torn. I thought about the alignment but wouldn't it cause it at high speeds? And I had a friend say its probably a wheel bearing.
I inspected my tire and there are chipped threading on it also.
ItsYousefBro is offline   Reply With Quote
Old 12-24-2014, 12:49 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the forum! Sorry about the fender bender. You need to go get your car professionally inspected. It could be as little as an alignment...
Old 12-24-2014, 12:54 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
You probably bent the wheel.
swap it with another and see if the wobble moves
Old 12-24-2014, 01:34 PM   #4
ItsYousefBro
I did swap it and the wobble was still there and the rim isn't bent
Old 12-24-2014, 01:35 PM   #5
ItsYousefBro
Im gonna get on that. Thanks
Old 12-28-2014, 10:57 AM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Get it fixed. Wheel may look OK and be bent. Could be other damage. Impossible to tell without a thorough inspection and checking geometry.
When my wife curbed her car at <10mph on black ice, the k-member and wheel were both damaged. It doesn't take much, but it dangerous to drive.
C
Old 12-28-2014, 03:53 PM   #7
White64Goat
Did the front hit or the rear? If the rear, more than likely bent the axle. Hit the front, probably bent the hub. Would still take the rim that hit and have it spun on a balancer to be sure it's not bent.
The Following User Says Thank You to White64Goat For This Useful Post:
Ultramaroon (12-28-2014)
Old 12-28-2014, 04:58 PM   #8
ItsYousefBro
C
The dealership is asking for to much to get the car only inspected. But imma gonna have to do it. I do feel like the I lost a weight on the wheel and it needs to get balanced again.
Old 12-28-2014, 05:04 PM   #9
ItsYousefBro
It was the side, I slide against a guard rail. Only got body damage (which doesn't look to bad) and got that eheel wobble. The rear rim wasnt touched so it isnt an axle . Its comming from the passenger front wheel. I put the spare on the front and there was less wobble (smaller rim tho, which is why). The front rim was slightly touch tho.
Old 12-28-2014, 05:09 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's likely all bent some; axle carrier, axle, hub, peened the bearings... No shortcuts. Take it seriously.
Even if you don't notice it right away, putting new stuff over other damaged parts is a recipe for premature failure.
Old 12-28-2014, 06:27 PM   #11
Itzed
Drives: 2014 BRZ Limited
There is a lot of geometry in the front of the car that all had to be pretty close to perfect. Could be a lot of things. Don't guess, take it to someone who can inspect it.
Itzed is offline   Reply With Quote
Old 12-30-2014, 09:54 AM   #12
Ashikabi
Ashikabi's Avatar
I had a similar problem on a Del Sol(front wheel drive) and it was the knuckle/hub that was bent. I would start with a balance on the tire first instead of throwing expensive parts at it. Then if it still vibrates, look deeper
Old 12-31-2014, 09:21 PM   #13
wparsons
wparsons's Avatar
If it's a consistent wobble/vibration, it's probably not the alignment, a wheel bearing, bent knuckle/hub/axle, etc. It's most likely a bent wheel or a missing weight.
A bearing would grind and feel loose, but wouldn't be a consistent wobble.
A bent knuckle/hub/axle stub up front would put the alignment out, but again wouldn't wobble.
Alignment would pull/scrub, but again wouldn't wobble.
It's very possible to bend a wheel and not be able to see it by just looking. The only way to tell for sure is to rotate it and measure for any runout. If you take it to get balanced they'll be able to tell you right away if the wheel is bent or not.
As for cost, insurance would cover this. It's definitely something you want to get fixed properly just in case it's something much worse than just a missing wheel weight.
flickr
Old 12-31-2014, 10:52 PM   #14
Ashikabi
Ashikabi's Avatar
Getting it balanced will be a cheap first step. My friend had a bad wheel bearing and his wheel wobbled bad. A mechanic will be able to tell you for sure
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 01:35 AM
My car was wobbling at start up Astroboy Engine, Exhaust, Transmission 69 06-20-2014 12:31 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
NRG Rim/Wheel LIP PROTECTOR up to 22" Wheel - Various Colors - FREE SHIPPING!!! YURparts Wheels and Tires 3 12-16-2013 09:07 PM
