Old 12-20-2014, 08:54 PM   #1
dtrop
Drives: Wrb 2014 limited brZ
Crawford ecoblocks
Saw recent facebook posts regarding this new time semi-available by Crawford.
A stock 2014 sti saw 15hp gain and 18lbs of torque for the cost of $50 and an under $5 installation. I guess it's a maf sensor but I'm not entirely sure what it does. It also can see ~7% increased mpg. It only works on the stock intake.
They said it should be available on their website this weekend but are taking orders by phone.
Any thoughts? If no problems arise, it is undoubtedly the best bang for the buck mod and I'm curious what kind of numbers it can pump on in a twin. Even a 5hp gain to the wheels would be awesome.
dtrop is offline   Reply With Quote
Old 12-20-2014, 09:08 PM   #2
kodyo
Drives: Scion FR-S
I imagine this is a mod that only works untuned because it's tricking the computer doing the air/fuel calculations in some way.
I personally wouldn't do it, a tune seems like a safer more reliable way to get these gains.
kodyo is offline   Reply With Quote
Old 12-20-2014, 09:12 PM   #3
J_kennington
Drives: 2013 asphalt scion FRS
Every thing I've ever seen from Crawford does BHP. Not WHP. So in reality at 15 claimed horsepower, your actually only getting a 2-3 bonus to the wheels
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 12-20-2014, 09:13 PM   #4
White64Goat
Crawford makes them for the twins but they're far from $50 and $5 installation. Believe they are called Crawford Billet Power Blocks.
Old 12-20-2014, 09:39 PM   #5
dtrop
Yes this only works without a tune.
The billet blocks are a different product. This is a new product that they have been working on for years, apparently.
2-3 hp for $50 isn't bad. Consider this and a k & n filter and you have 8ish hp for under $100.
Old 12-20-2014, 10:51 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Not sure if I should be suspicious or excited...
Old 12-20-2014, 11:58 PM   #7
steve99
Looks like a spacer fitted to maf sensor.
Suspect it shifts maf sensor slightly out of the main air flow in intake.
Suppose this would make the sensor detect slightly less air flow, ecu would then be fooled into injecting slightly less fuel as the air flow detected by maf sensor would be less but the actual air flow would be same.
Maf sensor also used as input to engine load calculation so it going to shift a lot of things like timing vvt and ignition arround.
Probaby relies on most stock turbo cars running rich for safety so leaning it out theoreticly gets you better economy and a bit of power.
it all seems a bit dodgy
would it work with a stock 86/brz who knows but gains if any would be less than turbo car.
Old 12-21-2014, 01:03 AM   #8
Poodles
Drives: 2015 Series.Blue
Pretty sad seeing a product like this from a reputable company...
I want to use worse language, but I'd rather not be banned.
Old 12-21-2014, 08:11 AM   #9
dtrop
I thought I read that results would be best on a stock twin.
Yes, it seems a bit sketchy, but what problems could this actually cause?
Old 12-21-2014, 10:53 AM   #10
steve99
If your tuned you can alter the maf scale ignition timing fueling exhaust/intake valve timing ect in the desired amounts to obtain better performance or suit you modifications
This spacer it appears will just artificially offset the maf scaling, could possibly cause drivability problems or just may not work at all on a non boosted car.
Old 12-21-2014, 07:07 PM   #11
dtrop
So it would be beneficial for those who are untuned and haven't added FI.
Old 12-21-2014, 07:21 PM   #12
Poodles
Possibly. The issue here is that it's frankly dangerous to do stuff like this. It's stuff I've seen hack job "tuners" do instead of actually tuning a car.
For starters, their claims of increasing horsepower, increasing gas mileage, and decreasing emissions is 100% BS. If this was the case, the multi billion dollar car companies would have noticed this and done it themselves. The government breathes down their neck about emissions and MPG figures.
In reality though, it probably doesn't do much of anything as MAF sensor is in the tip of the pillar, so even if you pull the MAF out a bit, it's still reading the air the same.
Of course, there's always the possibility it's true and works (kinda like their power blocks, though I'm still not sold on those either).
Old 12-21-2014, 07:44 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Poodles View Post
For starters, their claims of increasing horsepower, increasing gas mileage, and decreasing emissions is 100% BS. If this was the case, the multi billion dollar car companies would have noticed this and done them
Ahh beat me to it.
Old 12-21-2014, 07:45 PM   #14
steve99
i agree with @Poodles it all seems a bit suspect and snake oil like
Crawford AOS with FBM kit whitefrs Forced Induction 40 10-14-2015 06:32 PM
WTB: Crawford BPB v86 Want-To-Buy Requests 0 07-20-2014 09:59 PM
Crawford AOS Thechow Engine, Exhaust, Bolt-Ons 2 06-23-2014 05:24 PM
FS Crawford AOS whitefrs Engine, Exhaust, Bolt-Ons 4 07-04-2013 10:31 AM
