Old 06-29-2013, 08:13 AM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Crawford AOS with FBM kit
So i decided to go with crawford AOS and i was doing the installation when i notice that my throttle body pipe has no port to connect to the top port of the AOS.
Is anyone running this with a fbm kit?
What can i do here?
Size:  195.8 KBName:  ImageUploadedByTapatalk1372504388.969955.jpg
Old 06-29-2013, 08:46 AM   #2
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I can also hear air coming out
The Following User Says Thank You to whitefrs For This Useful Post:
Kiske (10-13-2015)
Old 06-29-2013, 09:27 AM   #3
Frs300
Frs300's Avatar
Drives: Pile of junk
What can i do here?
top port can be vented to atmosphere. just run a longer house down to bottom of engine bay.
Frs300 is offline   Reply With Quote
Old 06-29-2013, 10:23 AM   #4
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Do i need a filter?
Old 06-29-2013, 10:26 AM   #5
Frs300
Frs300's Avatar
Do i need a filter?
you should
Old 06-29-2013, 10:39 AM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
Do i need a filter?
Yes you should. Under vacuum this port is pulling air into the crankcase.
Sent from my GT-S7560M using Tapatalk 4 Beta
Old 06-29-2013, 10:40 AM   #7
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
This is what crawford told me
Safe is not the correct term Wilbert, its not like the motor will blow up from the crankcase vent being open but its just not proper. If you leave it open then you will not get a negative pressure on the crankcase which will make the piston rings not seal as well, plus you will smell the nasty burning oil smell constantly coming out of this hose.
sw20kosh (06-30-2013)
Old 06-29-2013, 10:55 AM   #8
Frs300
Frs300's Avatar
i ment to put should for the filter sorry. falling asleep at work
Old 06-29-2013, 09:48 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would just plug that port on the can, or if you want a hose to run to it, then just T the hose off the back of the intake manifold and run it to both ports on the can. I will stick with my vented catch can.
The Following User Says Thank You to King Tut For This Useful Post:
#maverick# (10-13-2015)
Old 06-29-2013, 10:13 PM   #10
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
Just bung ur intake pipe drill it and get one of those plastic taps with rubber seals and connect the hose
GT86drifter is offline   Reply With Quote
Old 06-29-2013, 11:40 PM   #11
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I put a small autozone filter lol
Old 06-29-2013, 11:40 PM   #12
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
There is a lot of air coming out
Wouldnt plug it be bad?
Old 06-29-2013, 11:48 PM   #13
whataboutbob
AutoX-10/10ths every run
@Gen has the FBM with a Crawford AOS. He should be able to chime in.
Build thread:Here
Old 06-29-2013, 11:52 PM   #14
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Awesome
whataboutbob (06-30-2013)
Crawford Edition FRS??? CAMBAM_6 Scion FR-S / Toyota 86 GT86 General Forum 11 06-23-2013 08:36 PM
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 ngabdala Engine, Exhaust, Bolt-Ons 11 06-10-2013 10:22 PM
FS: Crawford AOS xwd Engine, Exhaust, Bolt-Ons 6 04-07-2013 08:44 PM
Need help Crawford AOS install ngabdala Engine, Exhaust, Transmission 19 11-21-2012 09:04 AM
